http://providence.craigslist.org/mcy/1986706688.html
I am going to look at this tomorrow morning. Owner says that it has lost compression. Up to now I have only thought about the spree. Can anyone tell me about this one? Seems like a good deal. Front fender is cracked but otherwise all plastics are in tact. Seems like it might be a good winter project.
CL Find. Should I get?
1984 Spree With Taz BBK and Gears
1988 Seawind 24 Catamaran
- martynkim
Re: CL Find. Should I get?
Man, jump on that!!! a white one and $50! you can't lose!
50.00 jump on it, and its not an elitle, it an aero 50!! and white to boot
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
Is it easy to get parts for the Aero 80 motor? Upgrades? Would imagine if it has low compression, i would have to do rings at the least, or a whole top end rebuild. Does Taz have a kit for this? He also said that the door for the tool compartment was missing. Is that like the dreaded petcock cover on the spree? hard to find?
- martynkim
Its a 50 not an 80 has the variated AFO5E Engine. Parts are pretty easy to find. VT sells a BBK for it or malossi or even a used OEM bore and piston. (I have an extra)
- MrGoodwreck
- BMX
I would not wait till morning...
09 Ruckus
85 Spree
86 Spree
09 Apirlia <---- Gone
11 Zuma 125
85 Spree
86 Spree
11 Zuma 125
- martynkim
He also said that the door for the tool compartment was missing. Is that like the dreaded petcock cover on the spree? hard to find?[/quote]
Not too hard to find. Maybe hard in white but the other colors no problem.
Taz does not offer a bore kit for the nh80 but for this 86/87 nh50, he offers a 44mm BBK.catsailor wrote:Is it easy to get parts for the Aero 80 motor? Upgrades? Would imagine if it has low compression, i would have to do rings at the least, or a whole top end rebuild. Does Taz have a kit for this? He also said that the door for the tool compartment was missing. Is that like the dreaded petcock cover on the spree? hard to find?
Well, it is not an 80 because the kick starter is facing aft. On the 80 in is forward,
