it only sparks once
nitroelite419
it only sparks once
Post by nitroelite419 »
it was running fine earlier today, then it wont fire, took out the plug and checked it on the frame and its only sparking one time thats all, just a quick flash and thats all. PLEASE HELP
1995 honda elite
50mm big bore
v8 pipe
high performance cdi and coil
martynkim
Re: it only sparks once
Post by martynkim »
Bad Coil?
tw39515
Post by tw39515 »
also check the cdi.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
nitroelite419
just replaced it with a high performance one this morning
1995 honda elite
50mm big bore
v8 pipe
nitroelite419
i replaced both earlier today, Just did a 50mm big bore kit, performane cdi and coil, exhaust. Fired it up to check it out and it ran for awhile and then it happened
1995 honda elite
50mm big bore
v8 pipe
tw39515
Post by tw39515 »
the performance cdi's are not as good as the factory ones and tend to burn up. no personal experience just what ive heard.
in the us market the cdi's were not restricted so with the aftermarket ones dont show any improvement.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
Yeah, a performance CDI isn't gonna give you any thing except grief. Reinstall the stock one and it will probably fix it.
nitroelite419
ok i replaced back with the original cdi and i had awsome spark, so i put the plug back in and it fired for like 5 secs and and died. pulled the plug and the same thing, one little spark and thats all
1995 honda elite
50mm big bore
v8 pipe
kpa2004
Post by kpa2004 »
woodruff key? broke or not present?
kpa2004 wrote:woodruff key? broke or not present?
Even if the key is not there, every time the magnet passes the sensor, you should have a spark.
Try ohms checking the stator coils per the manual. While you are at it ohms check the ignition coil too.
New spark plug?
nitroelite419
WELP its the stator. Thanks guys for all the help and info. Is there any one one here who has a stator for sale???????
1995 honda elite
50mm big bore
v8 pipe
Post by eliteguy50 »
nitroelite419 wrote:WELP its the stator. Thanks guys for all the help and info. Is there any one one here who has a stator for sale???????
For what engine?
