1986 = 24 Year Old NQ50 Spree
I traded a China bike I got to use some parts off & $100.00 and got a old Spree .
I saw a post on this site from Sheldon and he did a great job on one of his .I hate to be a copy cat
but it just looked so good . I think I am going to enlist my Spree .
- Sheldons ride . he did a great job .
- 013fz.jpg (65.96 KiB) Viewed 10383 times
- Its been done befor .
- Military-Motorcycle-26.jpg (30.2 KiB) Viewed 10380 times
- Looks pretty good on a car ?
- camo_bentley_gt_0.jpg (142.05 KiB) Viewed 10382 times
Re: 1986 = 24 Year Old NQ50 Spree
Here is the start .
- rack bent
- 100_7052.jpg (160 KiB) Viewed 10378 times
- Here is the project bike
- 100_7051.jpg (164.82 KiB) Viewed 10380 times
- Traded this and $100.00
- 100_6952.jpg (159.51 KiB) Viewed 10382 times
Start with see whats there .
- The battery was OK & working but let the connectors sit in viniger for a while to get crud off
- 100_7091.jpg (198.18 KiB) Viewed 10380 times
- 100_7089.jpg (186.76 KiB) Viewed 10380 times
- Take clothes off
- 100_7061.jpg (196.39 KiB) Viewed 10379 times
Take plastic off
- Plastic off start stripping .
- 100_7098.jpg (163.08 KiB) Viewed 10380 times
- After 24 years the decal was kinda stubborn , Heat gun and razor blade.
- 100_7099.jpg (141.87 KiB) Viewed 10378 times
- no more advertising
- 100_7100.jpg (128.79 KiB) Viewed 10369 times
Cleaning Time
- Krudd
- 100_7126.jpg (141.01 KiB) Viewed 10366 times
- I start w/greased lightning , to break up and soften up the grease build up ,and it wont damage anything ,just spray let it soak a while then rinse off with water .
- 100_7133.jpg (164.35 KiB) Viewed 10367 times
- Getting there .
- 100_7139.jpg (186.87 KiB) Viewed 10362 times
Shoot carb w/ carb cleaning spray then into a parts cleaner bucket for a day or two .
- First of 3 carb cleans
- 100_7154.jpg (168.32 KiB) Viewed 10360 times
- 100_7157.jpg (207.62 KiB) Viewed 10361 times
- cleaner ?
- 100_7159.jpg (227.27 KiB) Viewed 10352 times
Go to plastic while carb is soaking .
- I used a wet sand to smooth out the damage .
- 100_7585.jpg (193.43 KiB) Viewed 10353 times
- paint test on side cover / there is a coat that gos on first so the paint will stick to the plastic
- 100_7586.jpg (167 KiB) Viewed 10350 times
- work on plastic while carb is soaking
- 100_7286.jpg (137.82 KiB) Viewed 10349 times
What to do while waiting for carb.
- Still nothing bolted
- 100_7696.jpg (163.74 KiB) Viewed 10350 times
- 100_7691.jpg (173.87 KiB) Viewed 10348 times
- Just placing the parts nothing bolted .
- 100_7686.jpg (170.1 KiB) Viewed 10347 times
Clean & blow out then install carb.
- 100_7883.jpg (173.63 KiB) Viewed 10345 times
- 100_7824.jpg (186.7 KiB) Viewed 10344 times
I can tell you right now that that air filter will make your motor run like crap and most likely melt your piston from being to lean. Unless you know what you are doing with tuning the stock air bos and filter arethe way to go.
Bear you are 100% Right . I have taken the carb off 3 times . and put it in soup for a day . Then clean clean clean blow everything out after the second time I put that filter on (1) for convience and (2) I was able to spray starting fuild directly into the filter , and it looks like it might be comeing off again Every time it gets a little betterBear45-70 wrote:I can tell you right now that that air filter will make your motor run like crap and most likely melt your piston from being to lean. Unless you know what you are doing with tuning the stock air bos and filter arethe way to go.
I did see a tool on this forum it was a set of different sized wire to clean out jets Sometimes its just that one stubborn clog that messes everything up .OK I will take it off and clean it one more time and try the smallest pin I can find and do some pokeing around .
But thanks for the good advice I am just to lazy to mess with the stock air cleaner ... let me get it running then I will put the real deal on ...
Here is a pic of the bike with the air cleaner I had to use a peice of hose and its a real tight fit so I am using the K&M cleaner .
- 100_7156.jpg (168.55 KiB) Viewed 10315 times
- 100_7074.jpg (175.65 KiB) Viewed 10312 times
- 100_7105.jpg (156.6 KiB) Viewed 10309 times
- bradthreee
If you need the proper air tube for that airbox I have one.
If you are using starting fluid to start your engine, it is bad for two reasons. First, it has no lubricating oil in it and washes any oil already there off, a bad thing at best. Second, if you get a crank case full of the stuff, and it doesn't take much with ether, you can have it explode in the crankcase and blow your reeds. 2 strokes and ether are a no-no. Besides that these engines start easy enough when everything is right. Oh and that aftermarket filter will cause hard starting too.
yeah, you will have a * of a time getting it to start with out the right filter and box on there.
make sure to check the pilot circuit (can see a pin * of light through it). a number 11 guitar string works good for this.
'62 125cc Honda cub
'62 125cc Honda cub
Hello Turtle As soon as I read this ,I thought that would probably save me a lot of time . I have heard about using a guitar string before but I guess I just like to do things the hard way . Instead of 11 I might as well get 12 and attach another 6 .... You talked me into it I will stop by a music store today . I know it will save me time in the long run . Thanks one more question on the #11 string acoustic or electric ?turtle13 wrote:yeah, you will have a * of a time getting it to start with out the right filter and box on there.
- Ready to Rock and Ride
- 100_0382.jpg (212.47 KiB) Viewed 10259 times
