1986 = 24 Year Old NQ50 Spree
Re: 1986 = 24 Year Old NQ50 Spree
Bear45-70 wrote:If you are using starting fluid to start your engine, it is bad for two reasons. First, it has no lubricating oil in it and washes any oil already there off, a bad thing at best. Second, if you get a crank case full of the stuff, and it doesn't take much with ether, you can have it explode in the crankcase and blow your reeds. 2 strokes and ether are a no-no. Besides that these engines start easy enough when everything is right. Oh and that aftermarket filter will cause hard starting too.
Hello Bear as for the starting fluid ... I am not the most patience person in the world and sometimes think a sledge hammer could solve all my problems with a carb .Hmmmm ? smash it or fix it ???
Smash it or fix it ?
martynkim
Post by martynkim »
My question is, do all your license plates say 666?
z50r-ghost
Post by z50r-ghost »
66SIX,
GREAT BUILD and pics, dude; thanks for sharing. :2thumbs: You have made some serious progress, bro - looks great so far!!
Keep us posted- later, j :twisted:
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
turtle13
Post by turtle13 »
66SIX wrote:
turtle13 wrote: Thanks one more question on the #11 string acoustic or electric ?
doesnt really matter... and wait... it would be the same either way. stainless usually works alittle better since its slightly stiffer, but whatever works. it wont go all the way through, but it will help clean the crap out. i usually dig through the trash can in my office and find whatever just came off one of my guitars last...
'62 125cc Honda cub
martynkim wrote:My question is, do all your license plates say 666?
Thats a weird question ? And the answer is YES .
This one was made in Italy . But I never drove it sat in my garage for years ... Just sold it this year  had 18000 original miles on it it was built in 1990 but it was fast .
Got rid of this a while back and got the Mexican car .
My junker or my ride . Had it for 10 days  then on New Years Eve a couple of years ago ,Bang rear 1/4 panel  trashed , Been driving it like that ever since . I call it my Mexican car  because when  I take it to Mexico no one will steal it .
Just got a small sandblaster cabinit woohoo ! I have been looking for one like this for a while as they stopped selling them 2 years ago , but are great for small parts and no mess . Also I got some rubber tiles that look kinda like diamond plate that I might put on the floorboard just testing them out now I was thinking glue them to some plexiglass cut to fit and just bolt it on top of the original one to save it from being damaged and also with the friction from shoes on flat camo paint probably not a good idea , I am also looking into camo wraps for the front plastic ,I went to a printing place that does that stuff and asked for some scrap peices to do some tests on how easy / hard it is to apply and what would it cost they said come back on thrs. and they will have some scrap peices available . a little here a little there .
I am still a little nervous about sanding the front plastic as it is in like new condition . But maybe after a few beers I will feel different about doing it (OK plug er in ) or hopefully get some camo wraps that look good and dont cost more than I paid for the bike .
Just looking at what the rubber mat will look like ? I don't know ?
Sandblaster works great
Little here  little there
Nice Epiphone, Six! To clean the carb, it may be wise to start with something even floppier than a steel guitar string. I've used a single bristle from a wire brush, held in a hemostat to get started. This avoids the risk of gouging the soft Aluminum Pilot passageway. If you do use a string, the smaller of the 2 "G" strings on that 12 string is usually of even thinner gauge than the high "E" on a 6-string. Fortunately that tightly-wound G breaks often, so you have a ready supply of material... :)
UPDATE 10/14/10
I have been talking to tazland001 and he has been beyond helpful . I said I was having some problems w/carbs
Taz said he would be coming to Vegas and said he could fix the stuff no problem . So we set up a meet . He showed up and said he needed 10 feet of shoreline and a sky hook ,I took off to get the stuff he needed and within 15 min. he had my Spree & Gyro running like rockets . Taz your a good guy & very talented big Thank You ! This forum has more than helped me out many times over without it I would have never met Taz .He even brought up the parts I needed and had a new ignition switch with a real key installed in min.s .
Taz wrote the manual  on Honda  Repairs
Done !  running scoots
Taz is fast and knows what he is doing
Now that Taz got this bike running so good I ordered some tires .
And will start on the painting or check out the camo wraps .
Ordered new tires yahoo
camo tires.jpg (40.33 KiB) Viewed 6970 times
Goodbye Tact
Goodbye Tact
load bike.jpg (130.48 KiB) Viewed 6965 times
For a little 50cc Taz got this old bike  Screammin
scremmin fast .jpg (160.08 KiB) Viewed 6966 times
Put new air filter on. Prep for paint /
wet sand
wet sand
new filter
new filter
small gas leak in  tank  need more J&amp;B weld
small gas leak in tank need more J&B weld
Paint small stuff
speedo cover
speedo cover
sanded down the decal but was  burned into the plastic
z50r-ghost
Man, i would love to have that Tact.... but looks like it has a good home.
nice work so far, devil dude-
later, jon :2thumbs:
...my life story
1990HONDANS50F
Dakine
Post by Dakine »
G d*** nice build and nice bikes..
tazland001
Post by tazland001 »
Devils dudes gyros are sweeeeeeeeet. The one I worked on hauls * for a stock set up.
My Tact now. lol
I am lucky got a pal and a tact(AF16)......
Taz
tazland001 wrote:Devils dudes gyros are sweeeeeeeeet. The one I worked on hauls * for a stock set up. Hopefully it will be cleaned & painted .
My Tact now. lol And it even has a racing CDI And all the parts are there .even the zip ties holding the plastic on .And the speedo goes all the way to 60
I am lucky got a pal and a tact(AF16)...... Thanks see you in a week or two Thanks again for all the help . And the Craftsman Ratchet .
Taz
Gee I wonder what I did today ??? Rewired the ignition ... someone cut all the wires on the connectors really short and put porciln screw cap connectors on (I know why ) after everything was rewired it wouldnt start ... It's funny how a fuse looks good but when you do a continuity check ,the cap is messed up and bad .
My favorite thing to do solder really short wires .Taz you really ought to let people know you  can get replacement switches w/ keys works great ...
Getting the rubber  diamond plate floor finished
I needed to get away from the spree and get my mind off it for a while .
