Did any 1986 Sprees have just electric start?
I was under the belief that the only sprees that did not have a kickstart were 84-85 Sprees. I just looked at an 86 that had a vin that matched an 86 and it had no kickstart. My thought is that the engine at some time may have been switched. Or were there a few 86 that had no kickstart?
'86 Spree NQ50 (Ported)
'86 Spree NQ50 Stock
Re: Did any 1986 Sprees have just electric start?
All Sprees had electric starters. The 1986 and 1987 had kick starters along with the electric starter.
So would all 1986 models have a kickstart then?
That's what I said if you read what I wrote.Bear45-70 wrote:All Sprees had electric starters. The 1986 and 1987 had kick starters along with the electric starter.
I understand that 86 and 87 Sprees had kickstart and electric start. My question was that if ALL 86-87 Sprees had the kickstart and if there was a special option to get an 86 sans kickstart. Thank you
- z50r-ghost
thadpk,
No, Honda did not offer a sans-kickstart "option" for the 86's and 87's.
my guess is you are right; either someone has swapped in an 84 -'85 engine in your '86 Spree, or possibly your '86 had a broken kickstart mechanism (or broken belt housing) and someone put an '84 - '85 belt cover on.
You could check this hypothesis by removing your non-kickstart belt cover to see if the drive pulley (on crank) has the small "splines" around the perimiter of the crank nut; that would mean you do in fact have an '86 engine, with an '84 - '85 belt cover. Just an idea -
later dude, jon
later dude, jon
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
...my life story
1990HONDANS50F
Thanks for your input!
- KeithMcFly
- BMX
Let us know the outcome. Keep us posted.
