Dimensions of piston?
Gingerbread Man
Post by Gingerbread Man »
I am looking for the dimensions of the piston for the NQ50 and SA50. I order a new piston kit for my Zuma and received the wrong piston and rings. Pictures are a plus, please include weight in grams if possible. Somehow I ended with a 40.50 piston and rings stamped 1.50 over. If the dimensions match I'll bore your cylinder to match the piston for a reasonable price. To clarify the piston I have is 40.50. Trafficjamz can you hook me up?
2007 CH80
Re: Dimensions of piston?
'94 up Elite SA50 is 39.0mm piston, 12mm pin. Spree, SB50, variated AF05 engines - Aero50 (85-87), Elite SS and SA50 to '93 are 41.0 mm stock pistons, 10mm pin.
Gingerbread Man
Great info mousewheels. Mine is a 10mm piston boss. What I'm looking for is the height of the piston. And the Spree is 41.00mm also. Dose this look like a Honda piston? The one on the right.
2007 CH80
Hmm...Pin looks low for a Honda Spree or early SA50 with a 10mm pin. Top of pin to top edge of piston is about 0.575"
39mm af16e stock piston 58.2g on my scale
41mm nq50 stock piston 50.8g on my scale
the one on the right looks like a elite S piston
Post by eliteguy50 »
Where did you order from? Yami dealer, Honda dealer, after market?
Gingerbread Man
Do you have a picture of the Elite s piston?
I ordered from Autotech355 on ebay. Carlos sent me a new kit and I get to keep the wrong kit.
2007 CH80
Gingerbread Man
mousewheels wrote:Hmm...Pin looks low for a Honda Spree or early SA50 with a 10mm pin. Top of pin to top edge of piston is about 0.575"
Thanks, mine is 24.50mm.
2007 CH80
.86 inches = 21.84400 millimeters
Gingerbread Man
I was measuring from the top of the crown when I had 24.50mm. I believe we have now measured in the same location and came up with equal numbers. If our numbers are correct I'll say these are the same piston.
2007 CH80
You guys took nearidentical photos. Wee bit of scaling and we have this :D
mousewheels wrote:You guys took nearidentical photos. Wee bit of scaling and we have this :D
Wow that is weird :confused:
My piston only weighs 58.2 grams. Yours is 64.5 grams. I wonder why that is?
I hope you use that scale to weigh other peoples bags :naughty:
Gingerbread Man
Awesome!
I think it weighs more because it's bigger?
I weigh lots of things on that scale. Like pistons, my pre-mix oil and rollers to name a few. :thumbwink:
2007 CH80
Yours is not a 39mm stock piston?
