speedo doesnt work
spreegirl
speedo doesnt work
Post by spreegirl »
My speedo doesnt work. Anyone have an idea where to start?
87 Honda Spree
85 Honda Spree
Re: speedo doesnt work
Pull the speedometer cable at the front hub - it's the easiest, and check for a broken cable. Or pull the top plastic, and check at the speedometer.
Suggest you begin by blocking up the front wheel so it can be spun. Remove thr cable end from the hub and give the front tire a spin. The rectangular cable socket should rotate slowly.
If not, the hub drive may be stripped and the cheapest fix is a new used brake panel.
Pull on the cable core, it should slide out. Did I mention rubber gloves? This particular grease stains pretty much permanently, so don't work over your priceless Persian rug.
The cable should be qiite long - enough to reach the cluster. Its other end should look like the hub end7n smooth and uniform.
If it's obviously too short, or the end is jagged, a new core from the same model should be installed after you remove the other end from the speedometer.
You should be able to see the needle jump a little when you spin the end of the replacement cable.
If not, the speedometer itself may have failed, but that's rare. After all, I's a Honda.
spreegirl
Post by spreegirl »
the cable at the wheel just pulls out?
87 Honda Spree
85 Honda Spree
bradthreee
Post by bradthreee »
There is one phillips screw on the hub that release the cable
