this is what happened
nitroelite419
Re: this is what happened
Post by nitroelite419 »
so is a 130 main and a 45 slow what you recommend also? Like tj said
1995 honda elite
50mm big bore
v8 pipe
high performance cdi and coil
Tj knows more about the jetting of this carb than I do, listen to him.
evilone
Post by evilone »
nitroelite419 wrote:so is a 130 main and a 45 slow what you recommend also? Like tj said
I recommend a 138 main and a 55 pilot.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Evilone has been tuning these carbs longer than me.
His suggestion is probably a safer combo than what i suggested.
I would buy a bunch of different jets. Elevation and temp have a lot to do with what jets you will need.
Also disable the power jet if your carb has one. (the pink tube that leads into the mouth of the carb)
I stuff little ball bearings in the tube to disable it.
The main jet is super easy to replace in an OKO carb. Tools required are a 17mm socket and a 1/4" nut driver.
The too small main jet in you carb now is your problem for sure.
evilone
Post by evilone »
Trafficjamz wrote:I would buy a bunch of different jets. Elevation and temp have a lot to do with what jets you will need.
My jet recommendation is based on a similar setup and my location. get a bunch of different jets like Tj said.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
nitroelite419
ok got my jet kits installed a 140 main and a 50 pilot, my idels good, but now its dripping oil out of the exhaust and theres a lot of gas comin out the carb???????
1995 honda elite
50mm big bore
v8 pipe
nitroelite419 wrote:..................................theres a lot of gas comin out the carb???????
Where is the gas coming out of the carb?
nitroelite419
out of the overflow and between the carb and bowl theres alot
1995 honda elite
50mm big bore
v8 pipe
Then your float is either bad or you have trash in the needle and seat. Do you have new fuel lines and an additional in-line fuel filter? If not change the lines and add the filter.
Bear45-70 wrote:you have trash in the needle and seat.
Take the carb bowl off and clean it out. You might have got some dirt or something down in there.
StrokedSr
Post by StrokedSr »
the jets that are stock in that carb are 130main and 39 pilot...
1988 yamaha zuma
polini evolution kit
polini evolution 2 exhaust
polini big reed manifold
dellorto 21mm
keli clutch
keli variator
nitroelite419
i guess the Keihin carb i hace is a copy carb, Its like 3 differt carbs built into one, Im going to try to mix up another batch of gas, Its still really smoky and boggy
1995 honda elite
50mm big bore
v8 pipe
Did you get the gas to stop leaking out of the carb?
nitroelite419
im going to install the other fuel filter and see what happens, I hope thats the problem, I took the bowl off, its clean. The float wasnt sticking, so i dont know. Ill just have to try the filter..
1995 honda elite
50mm big bore
v8 pipe
nitroelite419
so the bigger the number on the pilot jets means what
1995 honda elite
50mm big bore
v8 pipe
