fuel ratio
nitroelite419
fuel ratio
Post by nitroelite419 »
was wondering what fuel ratio everyone was running????
1995 honda elite
50mm big bore
v8 pipe
high performance cdi and coil
Re: fuel ratio
There is no way to know easily. Optimum air to fuel ratio for performance is 14 to 1 but economy is about 18 to 1. But without expensive equipment there is no way to tell what an individual engines fuel to air ratio is.
nitroelite419
Re: fuel ratio
let me ask agein what is everyones oil to gas mixture
1995 honda elite
50mm big bore
v8 pipe
evilone
Re: fuel ratio
Post by evilone »
32:1
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
veedubh20
Re: fuel ratio
Post by veedubh20 »
32:1 ftw!!!!!
for every quarter of gallon , which is 1oz.
axo
Re: fuel ratio
Post by axo »
I'm doing 50:1 now with Castor oil.
1989 Honda Dio SP
AF18E - 82cc Taiwan kit - 24mm Oko - KRS pulley kit - Kevlar belt - 8.44:1 gears - 1000RPM Center spring - 7 grams roller weights - R1 sectional exhaust - 130lb pilot :)
Re: fuel ratio
Bear45-70 wrote:There is no way to know easily. Optimum air to fuel ratio for performance is 14 to 1 but economy is about 18 to 1. But without expensive equipment there is no way to tell what an individual engines fuel to air ratio is.
:bowrofl:
I suspect Bear knew that this question was NOT about AIR to fuel ratio.
Re: fuel ratio
axo wrote:I'm doing 50:1 now with Castor oil.
:surprise: That seems dangerous to me. :nervous:
What carb size and jetting are you using?
axo
Re: fuel ratio
Post by axo »
24oko 48-122 now. Did not have the time to check for the jetting yet.
I think 32:1 is too much. Way too much smoke . Should be good for a racing setup but i am using the scooter for street riding.
Plus 50:1 is what the guys at VT recommended... Remember that Castor oil is very high performance. I would go 32:1 only if i am using some cheap stuff..
1989 Honda Dio SP
Re: fuel ratio
axo wrote:24oko 48-122 now. Did not have the time to check for the jetting yet.
Are you still running the oil pump?
veedubh20
Re: fuel ratio
Post by veedubh20 »
castor 927, recommed 25:1 to 32:1 .
50:1 to 32:1 need to retune jets on pilot and main.
You may not be aware of oil brands are not same premix ratio as 32:1
Some oils or are thick or thin.
JJ Joseph
Re: fuel ratio
Post by JJ Joseph »
veedubh20 wrote:castor 927, recommed 25:1 to 32:1
I don't get it. Why are you using premix if your Elite has an oil pump? It's not a chainsaw.
fastplastic
Re: fuel ratio
Post by fastplastic »
all my bikes have oil pumps removed and i run premix, bear disagrees with this but o well lol... and some ppl add extra oil to tank and run oil pump for big bores......
Re: fuel ratio
I disagree with removing the perfectly good and functioning oil pump just because you want to run extra oil. Just add a smidgen of oil to the gas to bolster the oil/fuel ratio rather than have to carry a lot of extra oil to run without a pump. I do agree with "add extra oil to tank and run oil pump for big bores......".
Spreetard
Re: fuel ratio
Post by Spreetard »
The factory spree pump supplies somewhere in the 70:1 range :surprise: I like my 32:1 smoker, but there will never be agreement on anything to do with lubrication. Between 30:1 and 50:1 seems to be the usual range, although there are alot of variables in play.
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
