If you are having fuel run out the overflow then the needle and seat can NOT be good, because that is the only way fuel can get into the carb. If it is working properly you can not have fuel out the overflow vent.nitroelite419 wrote:im going to install the other fuel filter and see what happens, I hope thats the problem, I took the bowl off, its clean. The float wasnt sticking, so i dont know. Ill just have to try the filter..
Oh and the bigger the number on the jet, the bigger the hole in the jet, hence the richer mixture.
