Air temp
Cylinder head temp
RPM's
Max rpm's
Max head temp
speedometer
engine run time
I guess I will be losing my bright light indicator and oil light, but I am doing a HID con version too, and I premix oil and gas.
I will also not have a fuel gauge but do have a tripometer and I can always look in the tank .
void buying from nitroelite419. He is a deadbeat seller. Promised me parts shipped and tracking #. Once I paid. no items no tracking info. no responses
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
Trafficjamz wrote:I made this mount so I could install the speed sensor on the rear wheel.
How is the magnet attached to your wheel? It looks like you might have used a wheel weight bracket, but it doesn't look connected to the lip of the wheel. I've seen others just drill a hole through the wheel itself, but .... I don't know if that's really good for the wheel/balancing, I dunno.
87 Honda Spree,
XX Yamaha YSR50
92 Yamaha Jog -> Stock.
05 Kymco Super 9-> My cruiser
