spree wont start or on come
- 86elitespree
I hooked up a battery but the light dont come on and it does nothing when i hit the start. The thing will run if the kick starter wasnt worn on the inside but I am able to start it with a drill and socket. When I got it the fuse was a tiny little thing that was covered with tin foil I replaced it with a larger fuse but still nothing.
The headlight only comes on after start. Is the taillight coming on?
Are you pulling on the brakes while hitting the start button?
Admin, Hondaspree.net
- Musicman823
- BMX
- 85spreeelite
- 85spreeelite
Start working through the wiring harness, going from the battery out to where it quits working with a 12v voltage check light. Other than checking your chassis grounds (refer to manual), electrical problems require extensive troubleshooting.
- 85spreeelite
- 85spreeelite
