What about a crank? This '96 is still a Japanese crank but I know the Taiwanese cranks had problems with the c16 RPMs.bakaracer wrote:dont mess with that pipe. get a good pipe for your jog. knowing you ,you will want it to go faster.that pipe will limit you to only 8.5hp max. thats with a top performance mid race kit. find yourself a yasuni c16,c20,c21 or stage6 pro or r1200 pipe. the yasuni with a mid race kit will make around 13hp.more than enough to go 70mph with a 70cc kit setup.Trafficjamz wrote:http://cgi.ebay.com/ebaymotors/ws/eBayI ... 613wt_1163
Is this pipe for a 1996 jog?
Is this pipe ok too loud for street use?
Just got a 1996 yamaha jog
Re: Just got a 1996 yamaha jog
from what I know the japanese cranks can handle the higher rpms than the zuma or taiwanese motors. if planing on building an engine to race or to make at least 13hp ,its best to upgrade the crank anyways. with these engines to make higher hp,you need to get the rpm's up.10k just won't cut it as alot of the pipes sold in the US does.the tecnigas next r and the leo pipes makes its power below 10k.Thats why dyno test show that they make max power around 8.5hp.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
- Trafficjamz
I already bought the leo pipe.
I got the corsa kit too.
21mm carb and ct mani.
and this
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2150wt_939
http://www.youtube.com/watch?v=eQyvkYiq ... re=related
Yasuni c20-c21 will not work on the corsa bore..
it will work on polini evo1/2 and malossi mhr single ring.
Just send a message to gb motorsource, He know lots of jog parts and give advice on parts recommend..
http://www.youtube.com/watch?v=F7ycKmTs ... er&list=UL
- Trafficjamz
Got more goodies for the jog build.
The motor has been cleaned up a bit too.
find a rotor kit for it. frees up alot more power and rpms
91 yamaha tzr 250r
91 yamaha tzr 250r
- Trafficjamz
rotor kit?bakaracer wrote:find a rotor kit for it. frees up alot more power and rpms
please explain.
there are aftermarket rotor kits. this replaces the stock heavy mag and stator. the aftermarket ones are aluminum and weight about half the weight of the stock mag/flywheel. the ncy ones sell for about $250. the malossi ones are about $450. all the guys in europe that race minarelli motor bikes use rotor kits on their bikes. makes it rev up quicker and frees up rotational mass weight off the crank.so that means more hp too.every little counts in these small engines.
http://www.scooterpartsplace.com/ncy-al ... og-50.aspx
91 yamaha tzr 250r
91 yamaha tzr 250r
When you get to that level of performance, you should also remove the oil pump.bakaracer wrote:there are aftermarket rotor kits. this replaces the stock heavy mag and stator. the aftermarket ones are aluminum and weight about half the weight of the stock mag/flywheel. the ncy ones sell for about $250. the malossi ones are about $450. all the guys in europe that race minarelli motor bikes use rotor kits on their bikes. makes it rev up quicker and frees up rotational mass weight off the crank.so that means more hp too.every little counts in these small engines.
you can send stock flywheel lighten to battlescooter. $60.
Jog/vino does have a oil pump,crank driven by oil plastic drive. Oil pump need to removed.
- Gingerbread Man
I had my flywheel lighten from them.veedubh20 wrote:you can send stock flywheel lighten to battlescooter. $60.
- GEDC0026.JPG (121.13 KiB) Viewed 10944 times
- GEDC0024.JPG (131.79 KiB) Viewed 10944 times
2007 CH80
how was the lighten flywheel?
How that ride?
How that ride?
- Gingerbread Man
Having the flywheel lighten really did help. The acceleration is a little better. On the top-end is where the biggest difference was gained. It now reaches a higher RPM = more speed. Overall a very good investment for my Zuma.
2007 CH80
- Trafficjamz
Gears. Where do i find them?
No one on ebay has them for the 96 jog?
- Trafficjamz
Are there oil pump plugs for the 1996 jog?eliteguy50 wrote:When you get to that level of performance, you should also remove the oil pump.bakaracer wrote:there are aftermarket rotor kits. this replaces the stock heavy mag and stator. the aftermarket ones are aluminum and weight about half the weight of the stock mag/flywheel. the ncy ones sell for about $250. the malossi ones are about $450. all the guys in europe that race minarelli motor bikes use rotor kits on their bikes. makes it rev up quicker and frees up rotational mass weight off the crank.so that means more hp too.every little counts in these small engines.
Where could I find one?
