almost sick of this spree
Mike
Post by Mike »
WHAT IT DOES:
-will idle fine
-white exhaust
-will run fine at about 15mph
-after giving it full throttle for bout 10 seconds it will start to stall.
-if you shut it off and let it sit for a minute of two it will start right up and do the same thing.
WHATS BEEN DONE ALREADY:
1. i cleaned the gas tank.
2. cleaned the carb.
3. brand new air filter.
4. clean fuel and vacuum lines.
5. clean petcock.
6.clean jet/ and right size
7. air screw at right adjustment.
8. idle speed screw at right adjustment.
9. wont run with air box vented OR sealed off.
IM SICK OF SPENDING HOURS ON THIS SPREE AND MAKING NO PROGRESS. WHAT ARE MORE POSSIBILITIES.
'86 Black/red two-tone Honda Spree, pretty much stock.
bitteraspects
Post by bitteraspects »
option 1. give it to me :D
option 2. custom motor mount, a little welding, DIO MOTOR 8)
Mike
Post by Mike »
hahah no thankss
bitteraspects
it was worth a shot
MySpree
Post by MySpree »
your exoust is clogged, go clean it.
Mike
Post by Mike »
if it were clogged, i wouldnt be getting so much white smoke though ...or would i?
Kikwear
Post by Kikwear »
I want to burn mine too. Join the club. At least yours runs.
Check the belt and driven face. How many miles are on the scoot?
FastSpree1
Post by FastSpree1 »
no you would get white smoke out of it unless it was completly clogged. when you give it full throttle the motor is burning more fuel and more smoke because it is wide open. Hense you pipe is somewhat clogged when you open it up the smoke collects in the muffler and backs up. When it backs up it get forced back into the cylinder causing it to to bog out and die.
Mike
Post by Mike »
i just changed the belt last week, so thats fine
Mike
Post by Mike »
yeah that makes alot of sense, but how would i clean the muffler without cutting it open. last time i tried cleaneing an older muffler with water and clr i couldnt get all the water oout, it had to evaporate itself er whatever you wanna call it
Mike
Post by Mike »
and if cleaning the muffler doesnt do anything, what else is a possibility? that i havent done already
MySpree
Post by MySpree »
thats is i know the problems u are haveing are exactily what happend to me. i used dishwasher soap and water. then compressed air to clean it. then i put it on while it had a lil water in it. and it shot out the rest of the junk.
MySpree
Post by MySpree »
Mike
Post by Mike »
alright thanks alot ill clean it tomorrow
Your carb isn't clean. Your idle jet's plugged, and the bike is only idleing until the bystarter kicks shut. Reclean.
