86 fuel tank on 85 spree?
mattman
Post by mattman »
Is the 86 fuel tank different from the 85 or can I swap one for another?
bradthreee
Re: 86 fuel tank on 85 spree?
Post by bradthreee »
The petcock connections are different. Also the fuel sender on an 86 is a 3 wire and the 85 is a 2 wire.
The 85 tank itself will bolt up no problem between all year Sprees.
mattman
Post by mattman »
Thanks, So If I were to swap over the whole system... tank and petcock assy. from an 86 to my 85 everything should work out other than the fuel gauge?
martynkim
Post by martynkim »
mattman wrote:Thanks, So If I were to swap over the whole system... tank and petcock assy. from an 86 to my 85 everything should work out other than the fuel gauge?
Yes, you are right. :hi:
mattman
Post by mattman »
Either of you guys have a good tank and/or petcock you want to sell? The interior of mine is so rusted that I think I may be better off finding a replacement. So far I have run across a few 86's so that's why I was asking.
bradthreee wrote: Also the fuel sender on an 86 is a 3 wire and the 85 is a 2 wire.
I thought the 3 wire sender was an '87 thing (not 1986) :confused: ..... I could be wrong.
WestcoastSPREE
Post by WestcoastSPREE »
My 86 has a 3 wire so I don't know if there was an early 86 model that was different from a late 86.
My scooters are all made from mix and match parts. :oops:
like I said....I could be wrong.
martynkim
Post by martynkim »
mattman wrote:Either of you guys have a good tank and/or petcock you want to sell? The interior of mine is so rusted that I think I may be better off finding a replacement. So far I have run across a few 86's so that's why I was asking.
I have an 87 tank and an 85 but need to verify. Both nice and clean.
