Only runs "good" with the choke on
C3Killer
Re: Only runs "good" with the choke on
Post by C3Killer »
Ok, since I'm an apparent newb, I have an appt with a local bike shop to look at it tonight. Hopefully its something easy that I'm overlooking, and it won't cost much.
Here's my setup:
AF18E with 72cc malossi alum bore
28mm oko carb (don't know jets)
PG Long
Carbon fiber reeds
CT Mani
Uni air filter
32:1 premix
Whaddya mean, "don't know jets"? They were there in your admirably greasy hands a few posts up yonder. I can almost read the Pilot - for sure it's a Gin-You-Whine Keihin. With that setup the Pilot should be around a 52-58. If it's much smaller than that, it could explain why it needs choke.
C3Killer wrote:
Here's my setup:
PG Long
Carbon fiber reeds
CT Mani
Uni air filter
32:1 premix
Check/change the jets. :wink:
evilone
Post by evilone »
Try 58 pilot and 132 main. That was my setup with the malossi cast iron 72. My clip was in the center position on needle. That should be a good point to tune it from.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
C3Killer
Post by C3Killer »
Looks as though I didn't take it apart enough, the mech said there was a small piece of dirt clogging the jet. Runs like a top now! Whoo hoo!
sum-azn-kid
Post by sum-azn-kid »
for future refence to find an air leak spray brake or carb cleaner around the intake manifold, one area at a time. If you mtoor dies/ idle speed drops alot there is where your leak is.
zuma 125-sold
Ninja 250r-totaled
StrokedSr
Post by StrokedSr »
I had the same prob.. What number main to you have in? If it's the stock 130 you need bigger .. Mine did the same I got a jet kit and tried everything from 132 to 160 and 142 and 140 main both work good for me.. I'm in Florida and am using same pipe and same carb.. Good luck you'll get it
1988 yamaha zuma
polini evolution kit
polini evolution 2 exhaust
polini big reed manifold
dellorto 21mm
keli clutch
keli variator
