Expansion chamber muffler for the Spree(taz)
Re: Expansion chamber muffler for the Spree(taz)
ANDREW wrote: i cant wait to see the day when im smoking cars of the line on a lil honda spree :coolcruise:
The spree is not very fast "off the line" no matter how you mod it.
Why would the insurance change if you did a dio swap?
ANDREW
Post by ANDREW »
It wouldent change if i swaped in a dio motor but if i got a dio (full scooter) the insurance calls it a scooter and the rate changes basically i am in a rock and a hard place right i could go buy another spree to modify for 200 bucks its an 84 or i can get a running 1997 dio 50 sr for 300 what should i do?
2002 Yamaha bws 50
1984 Honda spree
1986 Honda spree
1986 Honda xr100r
1981 Yamaha yz 80
1969 Honda z 50 mini trail
The dio gets my vote.
Why is the dio considered a scooter and not the spree? Canada is weird.
ANDREW
Post by ANDREW »
Trafficjamz wrote:The dio gets my vote.
the spree is considered a moped because it has a maximum speed of 30 and a dio is faster so they call it a scooter, Canada is weird haha but i have decided to stick with the spree because its cheap to insure and it is fun to upgrade and i like the look of it better.
2002 Yamaha bws 50
1984 Honda spree
1986 Honda spree
1986 Honda xr100r
1981 Yamaha yz 80
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
Hey taz after your done with that CT intake mount I got something for ya. How bout designing a new gear for the spree's oil pump for use with the big bore kits you sell :smile: :2thumbs:
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
fastplastic
Post by fastplastic »
im thinking that might need to have a new crank to match your new gear you cant just switch it out it wouldnt mesh up right
Post by eliteguy50 »
fastplastic wrote:im thinking that might need to have a new crank to match your new gear you cant just switch it out it wouldnt mesh up right
Keep the shaft the same on the crank side and change it in the pump.
Ah man, well it was worth putting it out there
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
If you put more or less teeth on the gear, the diameter has to change or the gear won't mess right, at least with metal gears. It is not like plastic speedo gears.
Correct Bear. That is why it would have to change in the pump if the person wanted to retain the stock crank shaft. It would be cheaper to swap a pump than a crank and pump shaft.
Gotcha, thats a cool concept
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
patthesoundguy
Post by patthesoundguy »
Can't wait for this pipe for my spree, now that I am single again there is more money for scooter stuff :geekdance:
x2 man! :geekdance: :lock:
I cant wait to get my spree just put back together hahah
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
maddog
Post by maddog »
dude a honda dio is legal in canada but not in the u.s. but you can convert it real easy :nerd:
spree-rider
Post by spree-rider »
a dio is legal in the us dump s***
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
