good mopeds
- killerpancake
good mopeds
I've noticed lately, there has been a lot of companies that I've never heard of making mopeds, and I also hear that the mopeds they make are nothing but grief after the first 500 miles. Has anyone owned one of these mopeds that can verify that they're not up to par in the quality aspect? Or is this just with Bad Owners?
If it don't fit, force it. If it breaks, it needed to be replaced anyway.
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
another 88 yammy razz
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
- z50r-ghost
Re: good mopeds
I can vouch for the Chinese "GY6" 4 stroke complete and all - out "cheapness" 100%.
I have been a motorcycle and scooter technician for the past 15 years; 9 yrs at a Honda dealership, and now at a shop that specializes in mainly ALL scooter repair. Chinese "clone" 50cc scooters can be purchased anywhere from $300-$1000 (and that's for a brand NEW scooter). They have problems everywhere. Electrical, engine, fuel system, suspension, crap batteries...etc.
We usually see problems from 0 to 300 miles. There have been SO many cases of where the buyer buys a new scooter online, and it never even can be started. Usually this is due to whatever solution the mfg puts in the fuel tank to preven rust during overseas shipment to prevent rust. This orange, "oily" solution eventually makes it's way to the carb, clogging it before it ever sees fuel. We also see batteries that will not hold a charge from new, electrical wiring probs where the starter will not work because faulty switch, bad starter relay, & bad brake switches. I have replaced at least 100 regulators; the Chinese have not perfected their regulators at all. A bad regulator causes the headlight to burn really bright, and blow. I have seen Chinese belts break within 200 miles. Most GY6 50cc scooters have a front disc brake, and alot of times they leak from new or "chatter" when applied. The 50cc GY6 rear centrifugal clutches "squeal" from takeoff and often blow apart. Their roller weight outside surface is nothing more than cheap plastic. Even the kickstarter assembly have constant probs. The tolerances and metal quality is poor, which makes for a weak link with the kickstarter. When a GY6 50cc is getting no spark, 80% of the time it is the CDI box has blown, or the coil stops working. Lastly, alot of 50cc GY6 scooters are INSANELY slow and underpowered. On the other hand, I have done at least 30 full top-end rebuilds on a "50cc" GY6, and when I pull the cylinder and piston, it turns out that in fact the engine is a 70cc or an 80cc. These scooters are pretty quick, but were sold as a 50cc. I have read that in many cases the Chinese companies simply use what parts they have an excess of during production.
As for the 150cc GY6's... the most common probs include: after approx 500 miles, they get impossible to start. This is most always due to the valves getting extremely tight (due to heat) so they require adjustment. Guys on GY6 150cc forums set their valves incredibly loose due to this.
Next, the 150cc GY6 seem to blow stators constantly. (especially the brand "Ishimoto") Usually happens around 1500-2000 miles.
Another common problem with the 150cc's is carb quality. Their carbs are really finicky, and some carbs are impossible to adjust from new. Sometimes even the air filter has to be removed for them to run correctly, and replaced with a less dense material. We have replaced many new scooters' carbs with replacement new Chinese carbs, and they still do not run as they should.
A common trait of ANY Chinese scooter is the body parts are made of the cheapest, most brittle plastic out there. The plastic will NOT survive a crash or a tip-over, let alone careful disassembly.
It shatters!
Anyways, remember this when it comes to scooters: You get what you pay for.
I will vouch for Tawainese quality. Brands like Adly Moto, Keeway and SYM make some top-quality scooters, AND come with warranties. As well, they run great. We sell these brands, and other than oil changes, tire changes, and basic maintenence, we never have issues out of them. SYM scooters in my opinion are the best Taiwanese scooters out there. SYM's quality is right there with Honda.
Hope this helps killerpancake-dude. If you DO end up with a Chinese "piece," you will end up paying in the end for parts and service. As well, if you choose to go Chinese, look for a 2 stroke version. They are NOT great either, but genearlly hold up alot better (and run better) than the 4 stroke GY6's.
Let me know if you need help. Or, you could just go with a Honda!!
- jon
It shatters!
- jon
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
...my life story
1990HONDANS50F
Re: good mopeds
I second the increase in Taiwan scooter quality. It is so good that Yamaha has been making some of their scooters their for over ten years. I have a Sundiro (Taiwan) 2t 50cc that has 7000 miles on it and runs great. I would not say they are as good as Japan scooters but they are close. Chinese bikes have a large range, some will go a few thousand miles with no problems and several will not even start. The wire quality was something that z50r-ghost did not mention but is a serious issue with Chinese bikes. Anything I've had or worked on from China has worse wiring than an American 7yr olds home built mini-bike. On some of the Chinese bikes, there is also a gel pack that is supposed to dissolve when fuel is added but that rarely works. I always pull the carb bowl to check for that pack, I've found packs that are only half dissolved on three year old bikes before. I would say Italian bikes are tied with Japanese bikes if not surpassing them for the wuality of new bikes. Even Honda has had issues with some of the newer bikes like the Metropolitan and Ruckus. Vespa has not had recent issues in the 50cc class that I know of. I have yet to have an issue with an Aprilia.
- sum-azn-kid
Re: good mopeds
did somebody say SYM?
I love my sym, has a honda dio motor(easy to modify and find parts) and disk brakes. Only thing is tires or wimpy only 3.00x10 i put on some 90/90-10 now it handles alot better. I've rode honda elite S and elite e and for its size the SYM handles the best IMO. And about reliability i ride my bike everyday on the highway up the hill to school about 20miles and it is fine.
zuma 125-sold
Ninja 250r-totaled
zuma 125-sold
Ninja 250r-totaled
Re: good mopeds
the sym moped is a good moped and reliable, stable handling...
check your local dealer if they sell SYM
http://www.cartersym.com/
- wikked_spree57
Re: good mopeds
x2 on the two strokes, i have an eton bemaer with 3000 miles that has done nothing more than break a belt since 1500 when we bought it. that was my fault, cause I abuse it, people think its funny when you're drifting through snow with the tire spinning but it's not so funny when you hit pavement and lose the belt.
I also had a 2001 Powermax 50 with the same 2 stroke motor, it had almost 11,000 miles on it and I just sold the motor on eBay for $100 and it STILL ran. I got bored with it so i parted it out.
1994 BMW 525i 5 speed BEAMER TIME
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned
- BMX
Re: good mopeds
I just got back from 3 weeks in Taiwan their scooters seemed to hold up real well. I rented one and got a SYM 125cc with over 9,000 kms on it. Speedometer and odometer weren't working and it had been beat hard as a rental but ran great and hauled us around with no issues.
Re: good mopeds
Sounds like a full-employment act for US-based scooter mechanics.z50r-ghost wrote:I have been a motorcycle and scooter technician for the past 15 years; 9 yrs at a Honda dealership, and now at a shop that specializes in mainly ALL scooter repair.
Admin, Hondaspree.net
- z50r-ghost
Re: good mopeds
...my life story
1990HONDANS50F
...my life story
1990HONDANS50F
