It was a clogged idle jetl I actually tried to remove it with pliers and pulled to hard and ended up breaking the idle jet tube with a piece left inside. Doh! Luckily I had another spare carb and not wanting to make the same mistake, I removed ALL gaskets from the carb and put it in a toaster oven at 300 degrees for 15 minutes. The aluminum expands faster than the brass tubes, and walah, the idle jet was easy to remove. I unclogged the idle jet by soaking in bath of carb cleaner and using wire. Then I spent all day drilling out the old piece of idle jet.
I cannot BELIEVE how small the hole is for the idle jet. This would be the first thing I look at from now on for carb probs.
Thanks for the tips Greg and Noiseguy on the previous posts they really helped
