Noiseguy rules! With SA50 manual
- ryanmcfinney
- Goped
Thanks for getting that up man! Can anyone tell me though is there any significant way my 1994 SA50 will differ from the info in that manual ( manual is for up to 1993 ) ?
Thanks again!
Thanks again!
The '94+ (Dio) is completely different. If you get a copy of THAT manual, I'd like to scan it.
- ryanmcfinney
- Goped
Mmm. The '94 should have the 50mm bore, not the 41mm bore used on the earlier models. If the engine looks the same, you should be good to go.
- ryanmcfinney
- Goped
- hrnytrtlsgsxr
- hrnytrtlsgsxr
Prior to 94 most engines were 41x 37.4mm 94 & up was 39x41.4 a longer stroke, in 98 the trans washer was eliminated in the final drive making it weaker & in 2000 the sealed beam was changed to a replaceable bulb, my manuals have personal notes attached so they stay with me but i have sent a copy to a friend who no longer needs it, just pay shipping.
Right, the '84-87 Spree, 85+ Aero 50, and 87 - 93 Elite all had the above bore/stroke, from what I've found. I'd thought that the Dio was even larger bore than stroke, but that's apparently incorrect.maddog wrote:Prior to 94 most engines were 41x 37.4mm 94 & up was 39x41.4 a longer stroke, in 98 the trans washer was eliminated in the final drive making it weaker & in 2000 the sealed beam was changed to a replaceable bulb, my manuals have personal notes attached so they stay with me but i have sent a copy to a friend who no longer needs it, just pay shipping.
If your buddy has a copy of the Dio manual that he'll cut loose for shipping, put me in touch with him and I'll go get it, scan it, and post it.
- ryanmcfinney
- Goped
- ryanmcfinney
- Goped
