125cc stroker project :D
Koert
Re: 125cc stroker project :D
Post by Koert »
Well here are some pictures from the cases! :D
what I used to fill up the threaded holes.. GOLD!! :P
transmisionside
transmisionside
Ignitionside
Ignitionside
Koert
Post by Koert »
Some more pictures! :D
Koert :coolcruise:
a look inside
a look inside
test assembly :)
test assembly :)
It looks nice! :D
It looks nice! :D
z50r-ghost
Post by z50r-ghost »
Nice work and great pics!! That bore and crank are HUGE!!! :2thumbs:
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
Koert
Post by Koert »
Monday I'm gonna visit a local tuner, to see what we can do. :D
He has a Yamaha DT50mx himself 14hp at the wheel :D
Koert :coolcruise:
Koert
Post by Koert »
Oh!
I have a question: Do you guys modify or use an other ignition?
Or do you use the original one?
Koert :coolcruise:
bakaracer
Post by bakaracer »
The stock cdi here in the states works fine all the way to at least 15k that I know of.the coil on the other hand,I would use a higher output coil for the higher compression you will be using or use a nology wire set.the spark will have a hard time making the jump with a high reving high compression engine.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Koert
Post by Koert »
So the ignition and flywheel itself stay unchanged?
No inner rotor ignitions? programmable CDI's etc?
Wouldn't it be a good idea to use a innerrotor?
The only problem I can think of is that the cooling would ben tricky...
Koert :coolcruise:
bakaracer
Post by bakaracer »
if you have the money to spend on those stuff,they will for sure help. the rotor kit more than anything. going from the heavy steel mag/flywheel to an aluminum one.that will free up some rpms and let the motor rev up faster too.
91 yamaha tzr 250r
Koert
Post by Koert »
I brought the engine to the tuner yesterday! :D
We desided that we will not weld extra material around the intake, because there isnt enough room for it. :(
I'm thinking about making the holes in the groundplate of the ignition into slots.. that way I can adjust the ignition timing.. :D
The flywheel will allso be lightend (6)
Koert
Very nice work Koert!
The last issue to conquer might be getting the cooling shrouds to fit around that tall cylinder. Have you test-fitted them?
Koert
Post by Koert »
I haven't test fitted the cooling shrouds yet! :nervous:
I didn't really have the time for it, and to be honest I hadn't thought about it yet.. :oops:
I hope the tuner is finisched soon! :D :P
And I'm allso looking for a different front fork...
Koert :coolcruise:
Koert
Post by Koert »
Well I have a nice intake manifold now! :D
It is an original Honda CR85 manifold! :D
My carb fits perfectly! :naughty:
Koert :coolcruise:
nice too!
nice too!
Nice!
Nice!
Does that setup use the stock reeds?
Why not just use the ct manifold and the bigger reed cage?
I am afraid that the stock reed cage will restrict your 125cc setup. :nervous:
Koert
Post by Koert »
I will be using the CR85 reedcage.
And I don't think that the CR85 reeds will restrict it at all :P
Why I don't use a CT manifold: I have to have it shipped from the other side of the ocean :shock:
And I am a verry impatient person! :P
Koert :coolcruise:
Koert wrote:I will be using the CR85 reedcage.
Koert :coolcruise:
Too far? :smile: my parts come from Taiwan too.
great build so far :thumbwink: keep up the good work.
