"Officially I'm Broke"
spree-rider
Re: Ruckus Horizontal Minarelli Build
Post by spree-rider »
THats what I run in my banshee! But I also use race gass
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
bakaracer
Post by bakaracer »
bradthreee wrote:Im running the Castor 927 @ a 32:1 ratio
ahh you should be good then. the kart guys use the castor 927 and run their motors to around 15k-17k and egt temps of 1100deg. I use that oil in my race scoot.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
veedubh20
Post by veedubh20 »
castor 927 oil burns clean .
bradthreee
Post by bradthreee »
Looks like the exhaust gasket didnt hold up. Also pulled apart the cylinder and checked for scratches. It looked OK and I added a metal base gasket to help lower the compression from 145psi.
Took a couple of pics:
Whats up with that spot on the piston?
bakaracer
Post by bakaracer »
If your going to add a gasket,add a head gasket.by adding a base gasket your raising the cylinder and making the port durations longer so now your moving the power band higher in the rpm range.your pipe makes its power in the 9400 to 10300 range so stick with the stock paper base gasket and add another head gasket.the carbon spot is normal.that might have formed before you switched to the castor927.if you polish the piston top,less chance of carbon sticking.that plug color is lean and its due to that exhaust leak you had.that gray/bluing going on on the ground strap indicates a very lean condition and almost detenation starting.
91 yamaha tzr 250r
bradthreee
I did notice that the guy who put together the motor for me used one metal base gasket and not the paper one. I have 1 paper base gasket and an additional 2 metal base gaskets that came with the kit. Ill use the paper one instead which is thicker than the metal ones.
Also the kit only came with 1 metal head gasket and the o-ringed head. Those 2 were already on when had 145psi. Any suggestions?
bakaracer
Post by bakaracer »
bradthreee wrote:I did notice that the guy who put together the motor for me used one metal base gasket and not the paper one. I have 1 paper base gasket and an additional 2 metal base gaskets that came with the kit. Ill use the paper one instead which is thicker than the metal ones.
no stick with the thin metal base gasket. he used that one because it keeps the port duration where it need for the pipe your using.if you use the thicker paper base gasket,your going to raise the cylinder up higher than it was and put it out of range of where the pipe makes power.get another head gasket so you will have 2 head gaskets along with that oring in the head.
91 yamaha tzr 250r
bradthreee
Thanks Ill try to order some from Stage6 distributor
bradthreee
bradthreee
Here's a little update. The Malossi Exhaust wasnt the right match for the Race Cylinder Kit so, had to ditch it for now and picked up a used Yasuni Pipe. It was in bad shape, so removed all the rust and painted it with high temp BBQ paint. Hopefully my engine will be happier now...
Next, decided to switch up the whole front end of the bike. Now its lower and nicer looking. I had troubles registering my old frame, so picked this one up that was already titled and painted black. There is a big ride I'm getting ready for the 27th of this month so between building mine and helping with my friend's, time will be scarce.
bradthreee
Measured squish @ 0.8128mm
Should be ok for 91 octane?
Squish tells part of the story. Measure compression too.
Can you not get 93 Octane in the PRC? What do the Maybach drivers fill wit?
fastplastic
Post by fastplastic »
I like the new black frame :thumbwink:
bradthreee
fastplastic wrote:I like the new black frame :thumbwink:
Thanks :smile:
Wheelman-111 wrote:Greetings:
No 93 octane over here in my neck of the woods...only 91
Last reading was @ 145psi, but that was with a different base gasket. I'll measure again. Where should I look to be @ wit 91 octane?
Another head gasket in there it would put my squish @ around 1.2mm
bradthreee
