darat
Posts: 3132 Joined: Fri Jul 23, 2004 10:24 am
Post
by darat » Fri Feb 17, 2006 4:40 pm
so do i just use carb cleaner and compressed air to clean it? i dont want to screw this up...
gman75
Posts: 60 Joined: Mon Jul 23, 1973 10:24 am
Post
by gman75 » Fri Feb 17, 2006 5:01 pm
-Make sure all 3 jets are clean in the carb
-Make sure you have all gaskets in the carb
-Make sure the airfilter area is airtight except at the intake of course (use duct tape if not)
-Make sure the bystarter is airtight (again duct tape)
- Make sure the oil pump is moving oil before you hook it up to the carb intake
Scooter-less
darat
Post
by darat » Fri Feb 17, 2006 9:31 pm
ok the first 3 on ur list is going to get redone.. now as for the autoby starter i am gettin really * about that hunk of *. i am just goin to put my elite one even tho i am goin to have to splice a couple of wires... i and not really rideing my elite now so..
darat
Post
by darat » Sat Feb 18, 2006 1:20 pm
So on the idel jet should i be able to see light?
darat
Post
by darat » Sat Feb 18, 2006 6:39 pm
i sware what a hunk if crap.. it is still getin to much gas... i am getin really *.. i have been workin on this d*** thing for 2 days.. i did run.. arg
darat
Post
by darat » Sun Feb 19, 2006 1:34 pm
i did clean it.. i noticed that the main jet was a 67 so i put a 65 back in it and tryed that.. but still getin way to much gas..
gman75
Post
by gman75 » Sun Feb 19, 2006 3:15 pm
you should be able to see light through all 3 jet holes looking straight down the carb with the float bowl off.
the idle jet hole is the smallest, you will see a tiny pinhole of light
i am using a #65 jet on my spree
Scooter-less
darat
Post
by darat » Sun Feb 19, 2006 3:16 pm
ok i can see light through 2 of the 3
darat
Post
by darat » Sun Feb 19, 2006 5:15 pm
i will let u guys know..
MySpree
Posts: 3291 Joined: Mon Jul 23, 1973 10:24 am
Post
by MySpree » Sun Feb 19, 2006 5:52 pm
hey hey hey i can can can fix it!!! u may be the master of elites but i know sprees top to bottom!!!
darat
Post
by darat » Sun Feb 19, 2006 5:55 pm
well u should u take apart sprees for fun..
MySpree
Post
by MySpree » Sun Feb 19, 2006 5:57 pm
well i do... i always take em apart. well i have a extra engine so i just play with that one. so far the one im playing with goes 42 mph with some porting and smothening.
darat
Post
by darat » Sun Feb 19, 2006 5:58 pm
dude just get a cdi unit unrestriced..
MySpree
Post
by MySpree » Sun Feb 19, 2006 5:59 pm
well then ill unrestric it myself!
darat
Post
by darat » Sun Feb 19, 2006 7:52 pm
YES YES IT RUNS WOOOOTTT
