It was stock and the exhaust, nose plastic and tail light were cracked. I got a smoked red jdm tail light from daywot one problem solved. Then I ordered a V8 pipe, variator, 9.8 gears, new belt and 2 k grab springs. This improved the topspeed to 42-45mph which was fun for a little while. I logged on and looked at wheelmans post for his 78cc bbk in great shape for half what a new one costs. I got that and installed it with a loaner 24mm carb from tjamz and a new set of 8.4 gears from limp. I also installed new tires 3x10 sl26 in the front and a 90/90 sl26 in the rear. It will now do 50+mph easy and still takes off faster then most cars do from the light. I will update with current pictures tomorrow in the day light.
*Picture Update*
New pics! Now running the 24 mm oko, polini corsa bore, pg long plpe, polini for ruckus variator, and a zx trans setup. Also did a color change thanks to z50r-ghost.
Now I have installed a hid headlight and me and tjamz finished the pod for the vapor. Also had the wheels power coated. Here are some pics
Turned out pretty well might try to make it better...
Top speed to date! ordering new taller gears soon
