polini for keli
StrokedSr
polini for keli
Post by StrokedSr »
my buddy has a polini overrange variator for the elite..i kno some mods need to be done no prob...but my ? is..should i trade him my keli for his polini?? :jack:
1988 yamaha zuma
polini evolution kit
polini evolution 2 exhaust
polini big reed manifold
dellorto 21mm
keli clutch
keli variator
Re: polini for keli
The Keli is a good $40 vario. The Polini sells sor a lot more, and is arguably a bit better.
If you're happy with tge Keli, and it's all tuned in, the hassle factor of fine-tuning the Polini should be considered in your decision.
The Polini "for Ruckus" needs case surgery to install, but is probably about the best you can get.
fastplastic
Re: polini for keli
Post by fastplastic »
doesn't take much to cut the case me and traffic jamz used a sawsall and made quick work of the carving process about 5 minutes then polish up with a dremal and your good to go!
Re: polini for keli
Post by eliteguy50 »
The Polini for elite 50 requires no cutting. It is a better variator than the Keli IMO. If the Polini is in good condition, I would do it. Does it come with everything in the overange kit?
StrokedSr
Re: polini for keli
Post by StrokedSr »
I'm pretty sure this needs a lil cutting,, soo i can put the polini and not have to worry about the rear clutch or belt?
1988 yamaha zuma
dellorto 21mm
keli clutch
keli variator
StrokedSr
Re: polini for keli
Post by StrokedSr »
Also it's just the vari not the whole overrange kit
1988 yamaha zuma
dellorto 21mm
keli clutch
keli variator
Re: polini for keli
StrokedSr wrote:I'm pretty sure this needs a lil cutting,, soo i can put the polini and not have to worry about the rear clutch or belt?
Correct, when swapping in the Polini for Elite 50, the only thing you need to change from your stock setup are the roller weights.
If the case needs cutting, you do not have the Polini for Elite 50.
StrokedSr
Re: polini for keli
Post by StrokedSr »
So if it's not for the elite
N I have to cut.. Am I gunna need a longer belt!?
1988 yamaha zuma
dellorto 21mm
keli clutch
keli variator
Re: polini for keli
The only time you need a longer belt (and it's also wider) is if you change the REAR pulley. ZX spec is 654 x 18 x 30.
Re: polini for keli
Wheelman-111 wrote:Greetings:
Or if you are working on a non-variated motor :wink:
