StrokedSr wrote:so t- jamz.. what you think.. can i hit 50 0r more with the setup i have meaning you think ill rev out to 10k?
You have 11.1:1 gears? or 6:1 like in your sig
A polini with a pg long should do 10k.
What top speeds are you looking for?
eliteguy50 wrote:It would be great to develop some sort of a camera to mount inside the belt cover so we could see where the belt is riding on the pulley at the moment of top speed.
A trail tech vapor gauge does this alreadymousewheels wrote: Neglecting belt slippage, given 2 tachs (front/rear pulley), this could be manually calculated. Anyone seen commercial products which gather the data, calculate and display the result? Adding the rear sensor to an existing tach/speedo computer would make a useful gauge.
Wheelman's 66.3mph @ 10k shows a variator ratio of 0.92:1 which is not too bad.Wheelman-111 wrote:
With 7.97:1s and a Giant 97mm Drive Face, Flash 3.2 went 66.3 MPH turning a bit over 10K -
