manifold problem
Mike
manifold problem
Post by Mike »
okay, heres the dealio. if i spray starting fluid on top if the spot where the carburetor and the intake manifold while the engines running i can hear a difference in the way it sounds. one of the o rings on the carb was bad so i bought a set and replaced what was bad. and i noticed that the red/orange insulator that goes between has a small crack but not big. but i bought one anyways so i should be getting it in a few days. once i put on the new o rings i tried out the starting fluid test and its still doing the same thing. now im starting to think that the intake manifold was shaved off by somebody a while back by one of the owners because it looks a little scratchy if you know what i mean. sooo if the new insulator doesnt solve the problem, would you think that i should go over the manifold and smoothen it out with something?because i dont want to spend any money on a new manifold. any advice is appreciated, THANK YOU
'86 Black/red two-tone Honda Spree, pretty much stock.
darat
Post by darat »
do u guys think that the orings can go bad... i never knew that.. mybe that's what is wrong with mine...
JF
Post by JF »
O-rings can go bad, but usually it's pretty old to begin with. Some O-rings deteriorate faster that others, while some may have just gotten the wrong combination of chemicals on it. No matter what, if an O-ring goes south on you, best thing to do is to either order a new one as soon as you can, or do like what I did and try to match yours up to one(or a box of em') at the local hardware store. I purchased a box of around 10 O-rings at the local Home Depot for a few bucks for one of my airsoft guns, but they also just so happened to replace the O-rings on both my starter and the oil pump as well. My advice; if you can, shop around, buy in bulk, and you could get out a lot cheaper than buying OEM O-rings from the dealer. Plus you'll have spares, so you will have enough to (hopefully) last for a long time.
Mike, if you can post a picture of the spot on the intake manifold where you'd need to smooth out, please do. That way we can let you know if or what to shave off of the target area. Also, make sure to check the reed-valve area for any leaks, and let us know when you get that new carb heat- isolater in.
JF
1978 Puch Free Spirit, a 1980 Honda NC50, a 1985 Honda Spree, and a 2005 Yamaha Zuma. Gotta love two-stroke power...:)
Mike,
Greg has seen most of these o-rings go bad in these scoots. I'd recommend replacing the o-ring with a new one (the plastic part can be reused.)
Mike
Post by Mike »
i already replaced the o rings, and air is still getting through. the orange insulator has a small crack so i ordered a new one and ill be getting it in a few more days.
Mike
Post by Mike »
air is basically getting through at the top and nothing on the bottom so if the new insulator doesnt work, the manifold was probably shaved off previously and uneven
uspmale
Post by uspmale »
I can send you a used manifold for $15.00 delivered.
or a ported one for $25.00 delivered.
All parts waranteed fo 30 days.
Mike
Post by Mike »
how much does a brand new manifold cost at a dealer
uspmale
Post by uspmale »
I just looked it up.
$45.14 sugested retail plus shipping.
Some dealers will give a discount.
MySpree
Post by MySpree »
i have manifolds! :D :D :D
darat
Post by darat »
mine has a crack in it do u guys think that would cause the problem?? of me getin to much gas...
It's cracked? Replace replace replace!
Email Greg at uspmale@yahoo.com. He's got a pile of manifolds. He's also filing them out for people that request it. Drop him a line.
darat
Post by darat »
when i say crack i mean the the bown peice that goes between the the carb and the manifolds
MySpree
Post by MySpree »
UHHHH DUDES WHY IS IT ALWAYS UPSMALE! I HAVE SO MANY SPREE PARTS I DONT KNOW WHAT TO DO WITH THEM!!!! I NEED ROOM IN MY GARAGE THATS WHY IM SELLING THEM UPSMALE IS TAKEING MY JOB AWAY!!!!
Mike
Post by Mike »
checked manifold, looks like its fine. i dont think it was ever messed with so a new insulator should do the trick. :?
