check out this plug
check out this plug
Need some input on a chop I just did. Running a 148 main 52 pilot 28mm carb on a malossi
- IMG_20110210_140049-1.jpg (22.43 KiB) Viewed 7853 times
- IMG_20110210_140214-1.jpg (20.28 KiB) Viewed 7853 times
- IMG_20110210_140218-1.jpg (20.77 KiB) Viewed 7853 times
Re: check out this plug
Man 24 views and not a single response lameeeee
- spree-rider
wgat sude if okug was facubg exaust?
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
Most would say it is good but I think it is one step lean, but then again I like my engines ti live and will sacrifice an mpg or two for longevity. Like Ron, my mentor always told me "You first have to finish, to finish first!"
Looks like the cardboard brown you want but i'd rather see the mixture ring at the base. Have you tried jetting the main a little lower and the pilot a little higher? I ran a 138 main and 55 pilot when i used the 28mm with the malossi, but you are in hawaii and i'm in michigan so that might make a difference. If anything i'd go a little richer than leaner...IMO.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
What was the steps you did to do your plug chop? Want to make sure you did that correct first before giving a opinion on the plug read. The first pic looks lean towards the base of the porcelain but the top is black which tells me the throttle was closed on decel or the egine was at idle for a little bit.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
Oh and go in detail on your plug chop. It doesn't take much to get a false reading.
91 yamaha tzr 250r
91 yamaha tzr 250r
I did the chop correctly. I rode it around for about twenty minutes and held the throttle wide open for about ten to fifteen seconds towards the end of the ride a bunch of times. When I killed the bike I was going wide open til it shut off. I have a stock uncut boost port
The only WOT run that counts is the last one. The rest are a waste of time.konaking wrote:I did the chop correctly. I rode it around for about twenty minutes and held the throttle wide open for about ten to fifteen seconds towards the end of the ride a bunch of times. When I killed the bike I was going wide open til it shut off. I have a stock uncut boost port
check to see what direction that white lean side of the plug faces when its in the head. mark the plug with a sharpie on the outer side so you can see what side it points to. then check for a leak or tighten the bolts up. I suspect thats the exhaust side where its more white on the porcelain on the plug.
91 yamaha tzr 250r
91 yamaha tzr 250r
Okay and what's the scoop with this cork ring that came with my kit? Some people here don't use it but it fit right in my exhaust port so I'm gussing its some kinda gasket. I'm running it now in my malossi with a v8
- images-8-1.jpg (3.13 KiB) Viewed 7785 times
That's the same color as my plugs, in general.
In the barn::
2001 Honda Elite
2002 Yamaha Vino
2007 Roketa Sicily
2006 Ninja 250
Special thanks to:
Workdog & Iggysepia for parts & quick shipping.
Evilone for buying my SA50P.
2001 Honda Elite
2002 Yamaha Vino
2007 Roketa Sicily
2006 Ninja 250
Special thanks to:
That's an exhaust gasket. You can also use an exhaust gasket like the VW in your avatar uses instead of the cork.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Yeah I got the vw gasket on there too. So no need the cork one then?
Not needed if you have the vw gasket.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
