honda spree bbk
honda spree 86
honda spree bbk
what kind of carb would be best for a 48mm bbk
and any other tips that go great with a bbk, besides pulley mod
Re: honda spree bbk
Spree gears. An intake setup so you can mount that new carb. Keep it small, maybe a 17.5 for a guess. A custom pipe would be great to really get the performance out of the setup.
honda spree 86
Re: honda spree bbk
not gears i already did pulley mod i got it goin 36 take off is decent, could you send me a link or someone who sells a new carb and manifold for it, thanks
- Petrock's 1984 Spree
Re: honda spree bbk
You will have to custom mount the new CT intake to your spree if you go that route. Check out TrafficJamz's thread in this section titled "CT for my Spree"
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Re: honda spree bbk
Quoth Petrock (the Hawkeye):
Go to Scooter-Center.com and search Vision Honda sections for an Arreche-for-Honda Amal clone carb.
These should bolt straight up if you choose a manual-choke version. There may still be a shock clearance issue.
The Arreches are excellent carbs and best of all the Pilot jets are selectable to overcome the fixed low-speed issue with the stock Honda carb.
I suggest a 17.5. Mine supported a 65cc Aero to over 55MPH.
That's one good way, but there is another, possibly cheaper and certainly easier:You will have to custom mount the new CT intake to your spree if you go that route.
- tazland001
Re: honda spree bbk
You got a link Wheel?
Taz
Taz
Re: honda spree bbk
Heres the Arreche:
http://www.scooter-center.com/scoweb/pa ... T_VERGASER
And a dellorto that may work:
1986 Spree w/ '87 SE50 motor
Re: honda spree bbk
With all due respect to Devenex, the pics show a spigot-mount fitting on the Arreche. Mine had a two-bolt flange that fit the Honda NB50 manifold and insulator perfectly. The Aero frame had no shock clearance issues with the included electric Bystarter. It might just be a generic pic, but that particular carb will require mounting to a spigot "Donut" or some sort of adaptor.
The Del'Orto has what looks like a Honda-type flange mount, but the "dog ears" are pointing up, not down. That probably won't fit either.
I went poking around the VERRY SLOW Scooter-Center site briefly, and I didn't find the carb I bought in early 2009. It might still be there, but there are 5 pages of carbs under Honda Vision. Mine had accurate pics of the Honda-spec flange mount, and it did fit perfectly.
Re: honda spree bbk
Perhaps this one:
Re: honda spree bbk
You're right!Wheelman-111 wrote:the pics show a spigot-mount fitting on the Arreche
I should have looked closer but I was eating my lunch at the time.
Re: honda spree bbk
^^^^^ is anyone running this? i was looking into the taz carb setup but this looks a lot simpler.eliteguy50 wrote:Perhaps this one:
http://www.hondaspree.net/phpBB3/viewto ... =4&t=19189
i'd prefer to not oversize and the 21mm seems kinda big.....
85 honda spree
07 honda ruckus
05 acura rsx typeS (sold)
07 honda ruckus
