no kick start rebound
87spreescoot
Post by 87spreescoot »
my kick start doesn't come back up, and i have to force it with a hammer backup. does this sound like a spring problem?
thanks
Re: no kick start rebound
Sounds like more than that. Something is binding real bad if you have to use a hammer. A bad spring would not rebound but it would not cause it to bind unless there as a piece of broken spring is jammed in between some moving parts.
Post by eliteguy50 »
Bear45-70 wrote:Sounds like more than that. Something is binding real bad if you have to use a hammer. A bad spring would not rebound but it would not cause it to bind unless there as a piece of broken spring is jammed in between some moving parts.
Agreed, pull off the belt cover and inspect it.
S4Patrick
Post by S4Patrick »
The C-Clip that holds the kickstarter gear probably came off/ come out of the groove that it sits in. It's binding the gear against the housing.
As the rest have said, you will have to remove the kickstart cover & inspect.
'92 Super Dio ZX - AF18 Corsa
konaking
Post by konaking »
Mine gut gunked upp once and stopped coming back. I never had to use a hammer but I had to pull it back up by hand. I just took my cover off and greased up the spring and moving parts. I would take the spring off the cover and check everything out and find your problem.
toboggan
Post by toboggan »
konaking wrote:Mine gut gunked upp once and stopped coming back. I never had to use a hammer but I had to pull it back up by hand. I just took my cover off and greased up the spring and moving parts. I would take the spring off the cover and check everything out and find your problem.
Like previously stated, I don't think it's a matter of greasing something as it would be replacing something. You shouldn't have to use a hammer. :surprise:
josh999
Post by josh999 »
Lol, I didn't see this post until just now, if you have a look at the "oops" post on here you might have the same problem as me :)
spewya
Post by spewya »
ive had that problem my self . it was the c clip kept coming off the gear .. i used some valve grinding compound and squared up the groove. it seemed to work for a while then i bought all new kick start parts becausr i didnt want any chance of it happening again when im out far.. take all the kick start parts out and clean really well then grease .also make sure there is a gasket in between the cover and were you bolt it up to the engine.
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
toboggan
Post by toboggan »
As stated above, most of the time that s*** locking up like that is caused by the smallest part of the kick start assembly, the cir-clip on the out side.
spewya
Post by spewya »
yeah .. i can garentee thats what it is
