rattle sound?
rattle sound?
I've got a slight rattling sound coming from my motor at 15 to 25 percent throttle only. Any ideas my bore has 700 miles on it and I'm sure its not piston slap.
Re: rattle sound?
By no means have I been working on these things long enough, but is it possible you have some rollers going out in the variator??
94 Elite S
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
Re: rattle sound?
No the rollers are almost new no flat spots. It sounds like its coming from the exhaust side
Re: rattle sound?
Now that I think about it I had a rattle at about half throttle and sometimes at idle as well. It ended up being the heat shield on the exhaust. I just took it off.
94 Elite S
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
Re: rattle sound?
Anyone interested in helping me out. Cmon *
- z50r-ghost
Re: rattle sound?
This ninja votes on checking the sidestand to see if it causes the rattle. I had one at the shop that rattled and it took me an hour to find it... J
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
...my life story
1990HONDANS50F
Re: rattle sound?
Could be anything. Does it rattle while on the stand? I have about 3-4 things which rattle on my SA50.
In the barn::
2001 Honda Elite
2002 Yamaha Vino
2007 Roketa Sicily
2006 Ninja 250
Special thanks to:
Workdog & Iggysepia for parts & quick shipping.
Evilone for buying my SA50P.
2001 Honda Elite
2002 Yamaha Vino
2007 Roketa Sicily
2006 Ninja 250
Special thanks to:
Re: rattle sound?
rattles like that could be center stand, variator ramp guides, of course worse case could be bearings
Re: rattle sound?
could it be a worn wrist pin
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
Re: rattle sound?
wrist pins, in my experience, even the worst ones, won't make a noticeable rattle.
Tru72 is right, i'd check those, last being crank bearings.
- killerpancake
Re: rattle sound?
could be as simple as a loose side panel or fan shroud.
If it don't fit, force it. If it breaks, it needed to be replaced anyway.
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
another 88 yammy razz
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
- Petrock's 1984 Spree
Re: rattle sound?
If you arent running the stock pipe, then throw the stock pipe on there if you have it.
That'll get rid of the exhaust noise and you'll be able to hear the sound better and maybe even isolate it.
Have someone in a car drive along side and see if they can hear it
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
