Finally going to place the order for the rest of my parts for my 94 Elite.
Getting the Polini Corsa, a Variator, Torque Driver (probably Polini since i think the Malossi TD needs to be lathed to clear the sping collar), and maybe a Clutch. Also Tach/Temp gauge that looks pretty cool - http://www.sip-scootershop.com/Products ... e+II+.aspx
Does anyone have part numbers for the Variators, there seems to be a few different ones and their descriptions are kinda vague. I have ZX rear pulley half already.
Also, any input on Variators from Polini or Malossi. Thinking I may just go all Polini for this one but still up in the air.
Thanks
Mike
SIP Order
Re: SIP Order
If you have the ZX-sized rear pulley, IMO a "For Ruckus" sized vario is the way to go. Polini's is about 94mm, don't know if Malossi makes a Ruckus-sized unit. If you use the 354 belt with a stock-ish SR front pulley, you don't get full "overdrive" and it decreases your top speed unless you gear way high.
The SR/Aero Malossi variator I had didn't seem to work as well as the equivalent Polini unit, but don't take just my word on that. The Malossi I had didn't have the plate bosses that extended proud of the casting for some reason, so its travel was more limited.
Re: SIP Order
I read that you had a Rukus Variator. I dont mind grinding the case a little bit to make it work so I will go that route. Although all of my Kymcos have used Malossi Trans parts, I think this time I will go all Polini, including the Torque Drive. Do you use the Polini Clutch as well?
Also, I have a 2.15 rim in the back, do you think I should go with 90/90 or 3.50 tires? I am thinking 90/90 becuase I think the differences are only minor from what i have read.
Re: SIP Order
I have a Polini 2-shoe adjustable clutch. ALL the clutches are too small, even the best aftermarket ones. But I really like the Polini because you can fine-tune engagement speed without dismantling.
For the record, I've never owned a stock Ruck vario, but have had a Polini-for-Ruck (94mm) and my
current ebay-scored off-brand 97mm faced variator. To this day I've never seen another, but I like it.
I recommend the 90/90 for the rear. 3.50 Michelin S-1 rubs the exhaust lug unless you shave 3/16ths there. Other brands may be better or worse.
The 3.50 is that much taller. 90/90 is actually a hair wider than the 3.50 but only 3.18 "tall". The 3.50 makes for a smoother ride up front, though, and over-corrects the speedo optimism a little.
30MPH indicated = 31 GPS, or about 3 % pessimistic. I can live with that.
