a custom made exaust
Spreetard
Re:
Post by Spreetard »
Base4life wrote:Sorry, i gess i was a little carbby when i said that. My appoligy. And yea i gess. MI back roads are not moped friendly.
Ain't that the truth. So... Base, Kenny, yall' gonna come up north and ride with us in the northlands? We've got a few REALLY nice backroads and near-weekly rides of 8-12 scooters. Lakeshore road and M22 are an amazing ride in the summertime... http://maps.google.com/maps?hl=en&sugex ... CBQQ8gEwAA
Methinks we Michiganders need to organize. The two biggest regional groupings of forum members are the Hawaiians and us. We have a dragstrip and winding, well tended roads in the greater Manistee area. And lots of typical * Michigan roads.
*I am sorry for the diversion from the topic of this thread. In repayment, I give you this: http://www.hondaspree.net/phpBB3/viewto ... =4&t=11085 an early trafficjamz creation, Before T-jamz made an account.*
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
bc117
Re: a custom made exaust
Post by bc117 »
spewya wrote:what do you mean stepped or not ???
its kind of hard to see because my pipes been cut and welded so many times but there are 4 sections to the stock pipe it starts out small and progressively grows larger
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
spewya
Post by spewya »
like it starts buy the middle of the fan cover, then under the fan cover then under the mounting bolts, then at the valve stem ??????
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
bc117
Post by bc117 »
yep does your pipe do that? ya know i could probly just look up what the spree exhaust looks like and tell you
1985 aero 50
ported
custom exhaust
ruckus vario
bc117
Post by bc117 »
just looked it up and yes the spree exhaust will work perfectly
1985 aero 50
ported
custom exhaust
ruckus vario
spewya
Post by spewya »
so all i would need to do is cut the outer part of the muffeler off and attach another chamber ???
i do have this hp exaust for a razz and i was gonna use that muffeler and my pipe .. would that be kinda the same concept
hp exaust 1.jpg (174.35 KiB) Viewed 6812 times
bc117
Post by bc117 »
nice pipe how well did it work on the razz? i guess i should come fourth and just say that i found the widestt and IMO strongest powerband when i kept all of the original pipe but if you want a purely topend pipe you can cut and weld up near the header or right before the muffler so that if you want to go back to stock your muffler aint screwed like mine is :naughty: heres some pics of how my pipe used to look back when my stock jazz could beat the gold pipe aero off the line and what i did to the muffler for the better black pipe
1985 aero 50
ported
custom exhaust
ruckus vario
bc117
Post by bc117 »
i highly recommend making a larger glass pack muffler like the one i made which will be unbelievably quiet BTW and will give better performance than a baffled muffler but you don't have to make yours out of a brake cleaner can :geekdance: also having the stinger start about 4 or 5 inches into the expansion pipe helps quiet them down a bit too... i should just make a youtube vid about my pipe but then i would need to get an account and learn how to upload a vid :|
1985 aero 50
ported
custom exhaust
ruckus vario
spewya
Post by spewya »
that i never had it on a razz .. also that would help alot if you mad a video .. because im a lil confused.. so should i try and make the pipe as short as i can??
bc117
Post by bc117 »
personally i would leave the pipe as long as possible i.e. chop up the muffler since it will give the most usable powerband but it would be alittle less work if you just cut the pipe before the muffler so your muffler is reuseable p.s just think short= topend, long= lowend
1985 aero 50
ported
custom exhaust
ruckus vario
spewya
Post by spewya »
ok so if i chop it were would you suggest i do it at .. just make the muffeler shorter of longer or what ??
Amateurs
spewya
Post by spewya »
what would u do bear
Without a lot more experience than myself I would not even consider building a pipe. It is half high science and half black magic and even if you have read and understand Gordon Jenning's book it is still not for those new to 2 strokes. For a Spree Taz will soon have a pipe and the other scooter all have some sort of pipe available. Just save your pennies and get something that will work better than than a stock pipe. But there is no such thing as a pipe that will boost off the line performance and add 5 mph on the top end.
spree-rider
Post by spree-rider »
Bear45-70 wrote:Without a lot more experience than myself I would not even consider building a pipe. It is half high science and half black magic and even if you have read and understand Gordon Jenning's book it is still not for those new to 2 strokes. For a Spree Taz will soon have a pipe and the other scooter all have some sort of pipe available. Just save your pennies and get something that will work better than than a stock pipe. But there is no such thing as a pipe that will boost off the line performance and add 5 mph on the top end.
X2 But don't even try because this kid is clueless
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
