bad crank seal?
SPREEtown
bad crank seal?
Post by SPREEtown »
i have a honda spree (build in sig) that has been PLAGUED with an air leak. after way too much time and money trying to track it down, i think i have found it, but i need a second opinion before i go raise *:
i got the crank bearings/seals replaced at a local shop and ever since this problem has been around, but i could not find any physical telltale leak signs. but after taking of the drive pulley(for the 20th time...) i found black gunky residue on the inside of the pulley/on the shaft, etc and it feels like a puff of air comes out when i turn the engine by hand. IS THIS A BAD CRANK SEAL? DID THE SHOP f*** THIS UP?
any info is appreciated
1986 Spree SE:
  • pulley mod
    '85 head
    SB50 intake, reeds, carb
    UNI filter
    44mm bbk
    3x10 conti zipps
    next:
    taz gears, sa50 clutch w/ 2k springs
Re: bad crank seal?
The shaft outboard of the seal ahould be bone-dry and clean as a whistle, even after thousands of miles.
The puff of air is just the cherry on the parfait. Seal can easily be damaged by ham-fisted "mechanics". Make 'em do it over.
SPREEtown
Re: bad crank seal?
Post by SPREEtown »
thanks wheelman
shop was cool about it. they said they were going to yank out the the old seal and press in a new one w/out splitting the case ( in an effort to save on labor, that im not paying for). is this a viable means of replacement?
1986 Spree SE:
  • pulley mod
    '85 head
    UNI filter
    44mm bbk
    3x10 conti zipps
    next:
evilone
Re: bad crank seal?
Post by evilone »
SPREEtown wrote:is this a viable means of replacement?
Yes
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
