Working on a Japan Gyro UP
OK I always wanted a Gyro UP they just look so weird .
Finally found one on Craigslist but it was in Miami ,That was a whole ordeal .But finally got it to Vegas .
Forget getting a service manual . Parts not easy to find . Its hard to try and figure out what was done to this over the last few years lots of tie wraps holding things together and a lot of guessing what is supposed to go where and what is missing ? Well here goes .
- Craigslist ad
- Miami Gyro .jpg (145.58 KiB) Viewed 10591 times
- 100_4401.jpg (174.03 KiB) Viewed 10591 times
- Made it to Vegas
- 100_4387.jpg (165.49 KiB) Viewed 10591 times
Re: Working on a Japan Gyro UP
Everything on this Gyro UP is different from any other Gyro sold in America .
The brake levers are motorcycle size .
Both wheels spin / bolt pattern on rear wheels is different from American sold gyros
Has a kick start / engine is compleatly different / I have been mixing fuel but it looks like they took out the oil tank
but who knows where it might have gone ? Does anyone have one of these ? I have a ton of questions .
- The gray box is the muffler cover
- 100_5010.jpg (174.14 KiB) Viewed 10589 times
- Weird frame
- 100_4421.jpg (157.94 KiB) Viewed 10589 times
- different bolt pattern
- 100_4406.jpg (142.61 KiB) Viewed 10589 times
Kick start thats one good thing .
Plastic lens and screw in bulb .
weird frame
weird frame
- 100_5076.jpg (203.03 KiB) Viewed 10589 times
- Headlight
- 100_5072.jpg (143.46 KiB) Viewed 10589 times
- Kick start thats a good thing
- 100_5030.jpg (177.49 KiB) Viewed 10589 times
There was no speedo cable so took one off a spree kinda almost fit got it up to 40 Km.
Also swapped out the ignition had 5 wires 2 were ground ( Thanks to Tazz he has some good aftermarket units that fit a lot of bikes )
- IMG_8641.jpg (146.08 KiB) Viewed 10589 times
- IMG_8638.jpg (150.37 KiB) Viewed 10589 times
- Rear end really different
- 100_5082.jpg (170.18 KiB) Viewed 10589 times
Trying to get the old paint and a shetload of bondo that was on the rear bed.
- 100_4414.jpg (145.46 KiB) Viewed 10589 times
- previous owner used some weird glue or something to try to repair the plastic . I am working w/ JB Weld it has worked befor
- 100_5087.jpg (137.12 KiB) Viewed 10589 times
- 100_5006.jpg (170.79 KiB) Viewed 10589 times
More pics
- The plastics come off easy enough
- 100_5035.jpg (152.81 KiB) Viewed 10589 times
- 100_4411.jpg (136.05 KiB) Viewed 10589 times
- IMG_8637.jpg (171.19 KiB) Viewed 10589 times
- bradthreee
Check out WeBike, its a Japanese site that has stuff for the Gyro you have there. Its not cheap.
You ever get rid of that thing I wanna be first on the list...
Thanks for the tip but I have searched there , and always the same thing batterys / cables / brake pads.
There are a few other things that fit windscreens / seat covers / bike covers .
Its always the same thing.... Google Gyro batteries you will find 100 try to do a search for a gyro stater or carb cover .
Once you put Gyro in front of anything the price goes up .
But I am sure you already know that .
I don't even think they made a service manual in english ? ( I think I need to do some checking in New Zeland thats where I was looking for one like this befor and there seemed to be quite a few )
I still would like to find someone else with this model and just ask a lot of questions .
But on the other hand its fast on the take off but I need to do some carb work to get the top end a little faster.
Also it seems to be different steering not as responsive as the American versions ,its like driving a truck .
- IMG_8658.jpg (129.2 KiB) Viewed 10583 times
- IMG_8659.jpg (149.43 KiB) Viewed 10583 times
- IMG_8660.jpg (142.52 KiB) Viewed 10583 times
Looks more like a truck....
....especially the way completely changed the rear suspension......not sure I'm crazy about that.......maybe it's better, IDK.....stay after it 6six6.........
- tazland001
Hey six you like you where having some fun.
Thats right I took those pics. hehe
Taz
Taz
Keep in mind that the Gyro exported to the US was for recreation and sport. In other parts of the world, they use this things for utility - as in actually carrying stuff. The Spree GVWR is something like 300 pounds, including rider and bike. The US Gyro probably has a similar rating. Not so good for carrying a load of rocks from the quarry...
I have still been searching the internet and this is the closest I have found what my bike is supposed to look like .
aaaaaah so that's where the oil tank is supposed to go ?
I did find some custom parts ... Cha...ching $$$
- OK thats where the oil tank goes
- gyro up oil tank.jpg (77 KiB) Viewed 10502 times
- This works
- 0711.jpg (149.22 KiB) Viewed 10502 times
- Gotta get this .
- 0703.jpg (147.1 KiB) Viewed 10502 times
I saw this ad for the Honda UP Thinking I should put my plate on ?
- 100_5101_1.jpg (112.84 KiB) Viewed 10497 times
- JAPAN 666 Plate.jpg (72.95 KiB) Viewed 10497 times
- gyro up 666.jpg (127.96 KiB) Viewed 10502 times
- chevyguyjay
Well painted a logo on the seat / made my own plate .
- 100_5219.jpg (140.9 KiB) Viewed 10440 times
