44mm or 48mm BBK
thistleb
44mm or 48mm BBK
Post by thistleb »
I have an 85 Spree, compression on the low side 90psi. I have been considerng a BBK. Have emailed Taz back and forth on the kits, super helpful. But like all my research I like to hear from other customers as well. My spree is clean and reliable, would like to keep it that way. That said I use is at my summer home in NH and some added power to handle the hills would be great. My understanding is the 48mm requires additional tuning to the carb and was wondering if its worth the additional tweaking. Thanks in advance
tazland001
Re: 44mm or 48mm BBK
Post by tazland001 »
Here is what I have to say. If you install a 48mm kit it is easy to tune. At least for me. This will give you way better acceleration and it will eat up hills. I have a 48mm kit in my spree and it takes off and accelerates much much better. I put a 48mm kit in this elite e I got for 80$. This thing hauls *. I was at a big motocross race this weekend at Mesquite, Nevada and jumped that elite over 4ft. It flew over the hill.
Taz
odinxxix
Post by odinxxix »
i have the 44mm kit and i am pleased with it, my son rides it and seems to like it. that said i was reading in another post that to run the 48mm it will need a bigger carb. can you elaborate. if ypu do tell us what is needed to get full potential out of it.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
tazland001
I just rejeted and it runs fine. I used a uni free flow. Its really not hard to dial them in. I just use my stock carb. The racing carbs will be avalable in a month for the spree.
Taz
spewya
Post by spewya »
will the 44 power the gears
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
spewya wrote:will the 44 power the gears
Yes
spewya
Post by spewya »
does taz only make one kind of gears for the spree ... will you get more out of the 48mm with out using a bigger carb bigger intake and tuned pipe than the 44mm
also if you use the gears with a 44mm will the acceleration be worse than if you used it with out the gears or will the accereration be better and top speed be better also
can you use a bigger carb bigger intake and tuned pipe with the 44mm and still get more out of it or is the 44mm designed to be used with all stock other parts just to give it that extra lil ommphh
spewya wrote:does taz only make one kind of gears for the spree
yes only one size
More what? Vibration......yes :smile:
44mm bore without the gears accelerates quickly but has the same top speed as stock.
Both the 44 and th 48 would benefit from a pipe and intake.
spewya
Post by spewya »
how fast will it go with gears
spree-rider
Post by spree-rider »
about 40-42 mph w/o intake pip or clutch spring. if you change thecenter sspring. you will probably get a couple more.
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
spree-rider
86 spree
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
spewya
Post by spewya »
i was gona port the in take try and make a tuned pipe out of the muffelers and expantion chambers i have .. what kind of center spring should i get ..
also can you get more power, top end, or acceleration out of a stock bore buy using a ported intake and tuned pipe
spree-rider
more throttle response and a little bit of everything alse
86 spree
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
spewya
Post by spewya »
okay cool
spree-rider wrote:more throttle response and a little bit of everything alse
Actually the opposite is true. A bigger intake track's throttle response is slower than a smaller one. just as a bigger carb hurts bottom end throttle response at the expense of loss of low end throttle response. The only thing this helps is the top end, AKA top speed and if you gain 1 mph you will be way more than lucky.
