Working on a Japan Gyro UP
Re: Working on a Japan Gyro UP
I was out in the shop painting the logo on the seat and kept going. I don't want to spend a lot of time on this and just want to get it done .
Here is what it looks like with no clothes on . I started repairing some of the plastic and getting ready to do a quick paint job tomorrow .Also to protect the decals that are left I have been putting a clear vinyl on them . I am going to try to find some rubber mat... black or hopefully gray to redo the pick up bed and floor panel .
I JUST WANT TO GET THIS DONE !!! (sometime this century )
- As you can see I am running out of room .
- 100_5274.jpg (222.72 KiB) Viewed 8310 times
- Hey Ho Lets Go
- 100_5234.jpg (167.08 KiB) Viewed 8310 times
- 100_5224.jpg (129.51 KiB) Viewed 8310 times
any close up pics of how the trans and motor setup looks ? is it anything close to a Dio setup ?
gyro moto are total different from dio... crank, bore,gear,,
What is the process for seat lettering?......Sure looks factory.........
I did a post on the seat logo .....HONDA Logo Seat Stencil Has anyone tried this ?motormike wrote:What is the process for seat lettering?......Sure looks factory.........
After a bit of practice it was actually easy . Just do some tests on some scraps first .
There is so much s*** in the way its hard to get a good pic of the trans. it is really weird . I have tried and tried to find any sort of manual or anything on this bike without success . I think I found the drain plug for the trans . but it is so low if I drain it how do I refill it ? If you know anyone with this bike have them PM me I have a ton of questions . Sorry I couldn't be more helpful .PureAloha wrote:any close up pics of how the trans and motor setup looks ? is it anything close to a Dio setup ?
Friday March 25 /11
Got another surprise today .The rear brake has been a little sticky so I poped the brake box that goes from 1 cable to 2 .... Rust Never Sleeps !
Then got some rubber matting for the pick up bed .
Then stuck a Honda Logo on the side of the pick up bed
- I think I know why the brakes were sticking
- 100_5295.jpg (121.61 KiB) Viewed 8279 times
- I went to a few places $12.00 a ft.
Lowes was $ 2.60 a ft. - 100_5290.jpg (112.57 KiB) Viewed 8279 times
- 100_5325.jpg (130.55 KiB) Viewed 8279 times
Friday March 25 /11
Also mounted the rubber mat for the pick up bed on some wood so I could remove it and just have the metal bed .
Also sanded and painted the back pick up wall .
- 100_5306.jpg (182.26 KiB) Viewed 8279 times
- 100_5323.jpg (150.56 KiB) Viewed 8279 times
- 100_5335.jpg (138.37 KiB) Viewed 8279 times
Friday March 25 /11
Finding out more and more about whats missing .
Like the 2 stroke oil tank ...
Oh Boy get to pre-mix 40 to 1
In the second pic I stuck some mesh to cover up where a cover probably went for the oil tank .
- 100_5340.jpg (162.98 KiB) Viewed 8279 times
- 100_5341_1.jpg (134.32 KiB) Viewed 8279 times
- 100_5342_1.jpg (162.22 KiB) Viewed 8279 times
How about some oak sides to give it the stock truck look,.......OR.....maybe a canvas top with bows for the MASH 4077 kind of look.........then there's the Keg???......oh yeah, the keg.......
Hello Motormike you know the canvas top idea is not that bad ...
You ask what did I do today ?
Worked on plastic ...
- did some repair put plastic behind plastic tomorrow sand & paint
- 100_5377.jpg (120.44 KiB) Viewed 8259 times
- 100_5376.jpg (138.17 KiB) Viewed 8259 times
- Cleaned & washed
- 100_5366.jpg (85.24 KiB) Viewed 8259 times
That rubber mat will help keep the fat chics from rolling off.....
They are fun to ride but don't let your friends see you on one .motormike wrote:That rubber mat will help keep the fat chics from rolling off.....![]()
- I would never let one roll off .Why do you think I have ratchet straps ?
- IMG_0157.jpg (91.62 KiB) Viewed 8237 times
- What was I thinking ?
- married.jpg (71.54 KiB) Viewed 8237 times
No I just try to see the inner beauty in a woman . And I don't have to worry about her riding my bikes ... I just show her the weight limit and tell her she is not worth a new set of tires .motormike wrote:....Shotgun wedding???.....
Yea right
