Working on a Japan Gyro UP
Re: Working on a Japan Gyro UP
I did some body work on my bike today and thought I would try some bondo to fill in some spots.
Bondo dosen't stick worth Shet .
I have better luck with J B weld .
Hey I gave it a shot .
- 100_5395.jpg (137.97 KiB) Viewed 8476 times
- 100_5392.jpg (106.98 KiB) Viewed 8476 times
- tazland001
Omg six those pics where killin me. I love the fat chick pic. lol.
The carb six has on that Gyro is kinda similar to the early dio AF18 carb. It uses the same dio jet.
Taz
Taz
I recognize this nipple from previous post about "wider mirrors"66SIX wrote:They are fun to ride but don't let your friends see you on one .motormike wrote:That rubber mat will help keep the fat chics from rolling off.....![]()
Hello PureAlohaPureAloha wrote:any close up pics of how the trans and motor setup looks ? is it anything close to a Dio setup ?
I took some pics of the trans. its like nothing I have ever seen .
Sorry I do not know a thing about this .
It's just weird .
- 100_5515.jpg (175.15 KiB) Viewed 8449 times
- OK I have no idea what it says ????
- 100_5506.jpg (120.41 KiB) Viewed 8449 times
- 100_5502.jpg (168.01 KiB) Viewed 8449 times
3/28/11 Actually got some stuff done today .Remember that rusted out brake linkage .
Got it cleaned up a bit and found out there is a chain and sproket in it to pull both brakes .
3 days of spraying it w/ WD40 and scraping w/ wire brush .
- Before
- 100_5294.jpg (178.69 KiB) Viewed 8449 times
- 100_5482.jpg (111.16 KiB) Viewed 8449 times
- 100_5493.jpg (127.79 KiB) Viewed 8449 times
3/28/11 took off the rear rim 6 Bolt (wonder if I can find some golf cart rims and wheels ) and I now know why the brakes are a little soft ...
Metal to metal .... Great now where do I find brake pads in America? The part # is ASK UPH I wonder if that means Gyro Up H for Honda ??? really ...really... weird size .
- 100_5466.jpg (122.63 KiB) Viewed 8449 times
- 100_5522.jpg (144.29 KiB) Viewed 8449 times
- 100_5532.jpg (131.38 KiB) Viewed 8449 times
3/28/11 did some touch up paint on the rusted tank / and frame .Then started putting some of the plastic back on .
The previous owner did some mods to hold the plastic on and had drilled holes so I just used the same holes and put some plastic scraps behind for strength ..
- vice grips after the parts were lined up and ready for drilling
- 100_5540.jpg (103.05 KiB) Viewed 8449 times
- you can see the J B weld at the top and the bolts holding the two parts together
- 100_5560.jpg (124.72 KiB) Viewed 8449 times
- I used some scrap plastic and put it behind the floor board and leg sheild then bolted them together .
- 100_5539.jpg (115.26 KiB) Viewed 8449 times
3/28/11 Had some scrap white vinyl laying around so I stuck it on the side of the floor board the color seemed to match .
- 100_5543.jpg (104.54 KiB) Viewed 8449 times
- 100_5545.jpg (121.21 KiB) Viewed 8449 times
- 100_5538.jpg (159.98 KiB) Viewed 8449 times
- bradthreee
Any 3 bolt tg50 wheels laying around? Willing to see if 3 of the 6 holes match up?
I can't beleve it "what a Dummy I am " .... What a maroon ... I had the wheel off What a dummy and I really wanted to check to see for myself .... Brad I just want to get this bike finished .bradthreee wrote:Any 3 bolt tg50 wheels laying around? Willing to see if 3 of the 6 holes match up?
Anyway 3/30/11 I have been fighting a bolt to get the rim off to work on the brake WD40 and a impact gun is not cutting it I guess I need to try liquid wrench . I searched and searched for brake pads for this bike w/ not much luck .So today I went to a Honda dealer what a waste of time then another bike shop then another bike shop finally I went to the Chinese scooter shop that sold me a 85 gyro for parts a while back ... I couldn't beleve it the guy had some new brake shoes that are almost a perfect match $40.00 for the pair the only difference is the hole is a bit smaller ... No problem I have a drill and the metal is a lot cheeper but at least I have a set of shoes that I don't have to order from Japan oh I also called some brake places that will re-pad the shoes $70.00 each .... Thats not going to happen . I installed one side it was a bit tight so I just sanded it down a bit ... works fine
- Yeahhhhhhhaa !!!
- 100_5580.jpg (149.54 KiB) Viewed 8427 times
- 100_5588.jpg (125.59 KiB) Viewed 8427 times
- 100_5600.jpg (120.83 KiB) Viewed 8427 times
3/30/11
Got my brake pads .... Whats stopping You ?
Made a little bar for the back ... To keep fat chicks from falling off plus the rubber mat and tie down straps also help .
- China scooter shop / Heart of a Honda wearing Shoes from China
- 100_5574.jpg (174.18 KiB) Viewed 8430 times
- Not attached just wanted to see how it will look
- 100_5577.jpg (164.49 KiB) Viewed 8430 times
- installed and painted
- 100_5617.jpg (75.76 KiB) Viewed 8430 times
3/30/11 even had time to paint my fenders ... I am so close to finishing this bike .
I just hope tomorrow the Gods of lubricant will be with me and release the stuck bolt from it's prison ,
So I can throw on the China shoes .. and then DONE DONE DONE !
- 100_5597.jpg (129.51 KiB) Viewed 8430 times
- 100_5599.jpg (98.09 KiB) Viewed 8430 times
- 100_5605.jpg (152.62 KiB) Viewed 8430 times
- tazland001
Lookin good six. Hey I will be in Boulder city this week for a race. I might be able to come by and do some work for yah. Six do you have the front headligt cover on that parts gyro? The one I got is all broke up and beyond repair.
Taz
Taz
- IMG_8681.jpg (153.47 KiB) Viewed 8412 times
- IMG_8690.jpg (78.56 KiB) Viewed 8412 times
- IMG_8715.jpg (225.01 KiB) Viewed 8412 times
More Pics
- IMG_8665.jpg (157.65 KiB) Viewed 8412 times
- IMG_8676.jpg (135.72 KiB) Viewed 8412 times
- IMG_8714.jpg (205.58 KiB) Viewed 8412 times
