1985 aero 50 mods
turtle13
Re: 1985 aero 50 mods
Post by turtle13 »
bc117 wrote:by the way i have the belt, clutch and clutch bell off a gy6 can i do the zx trans mod?
The splines on the crank are not long enough to space out the drive face out for the wider puller on the SE engines to do the zx- transfer unfortunately... unless you CA. Find a crank that matches our engines that is slightly longer on the splined side.
'62 125cc Honda cub
bc117
Post by bc117 »
heres some pics of my polished tranny cover, today i found out what was up with my take off, somehow grease got slung on the pads and bell. so i cleaned it of and cross hatched the bell with some sandpaper for extra grip and it now takes off way better, and then i added a forced air induction vents to keep the clutch cool.(notice the window screening i installed to keep crud out) but i will have to taker it on a long ride to see if it helps, also yesterday i got the ol aero up to a GPS verified 50mph! downhill... and 42mph+ on the flat but i think i could go faster on a smoother road
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
