40 MPH Spree
SpreeMadness520
Re: 40 MPH Spree
Post by SpreeMadness520 »
Trafficjamz wrote:
SpreeMadness520 wrote:
Everything is stock tires and all, Idk how it was possible but i was flying at 40. Possibly the ridiculous power to weight ratio?
Power/weight has more to do with acceleration than top speed.
You were probably going 35 tops. The spree speedometer is not very accurate with a 2.5 tire.
lol idk i still proved bear wrong. :woot: I bet i can break 40 after modding the dio lol
130cc Stroker
1984 Porsche 944
1965 Vespa
Re: 40 MPH Spree
SpreeMadness520 wrote:I know its going 40 by the needle next to 4 0
http://i1224.photobucket.com/albums/ee3 ... 0BITCH.jpg
If you have a 40 mph speed, it isn't a Spree.
Re: 40 MPH Spree
:surprise: :surprise: :surprise:
This is the first spreedometer I have seen that displays 10 20 30 40.
Is this a US spree? what is the VIN?
SpreeMadness520
Re: 40 MPH Spree
As in the number on the frame? The engine and the frame are different years
130cc Stroker
1984 Porsche 944
1965 Vespa
Re: 40 MPH Spree
on the frame.
SpreeMadness520
Re: 40 MPH Spree
Af0606fs145607
130cc Stroker
1984 Porsche 944
1965 Vespa
Re: 40 MPH Spree
SpreeMadness520 wrote:Af0606fs145607
are there numbers/letters before that? jh2 maybe.
Re: 40 MPH Spree
SpreeMadness520 wrote:As in the number on the frame? The engine and the frame are different years
Even if they are the same year, the engine number is different from the VIN. Oh and that is the engine number. The frame number starts with a JH.
SpreeMadness520
Re: 40 MPH Spree
Yes jh2? Why is that rare?
130cc Stroker
1984 Porsche 944
1965 Vespa
Re: 40 MPH Spree
no.....just means it's made in japan.
SpreeMadness520
Re: 40 MPH Spree
Oh ok lol
130cc Stroker
1984 Porsche 944
1965 Vespa
mopeds4sale
Re: 40 MPH Spree
Post by mopeds4sale »
Most sprees will not even run without the airbox.
If yours did 40 without it, it would be the first time in spree history. :surprise:[/quote]
Not always true Tjamz I have had several honda sprees that would run like a raped ape with no air box. And yes I have had one up to 38(flat ground) with no air box and GPS verified. Most will run with out the air box you just have to turn in the air/fuel ratio screw in all the way. I do not suggest doing this but when you buy a spree for $20 and can ride it like that for a summer it is well worth the risk.
RIDES:
85 Honda Spree
86 Honda Spree
87 Honda Spree
87 Honda Elite
93 Honda Elite
01 Regency Silverado
95 Tahoe
91 201 Liberator
woodman
Re: 40 MPH Spree
Post by woodman »
:coolcruise: my84 sprees speedo goes to 40 wish the spree would o-well still the most legal fun on two wheels!! :coolcruise:
Re: 40 MPH Spree
mopeds4sale wrote:Most sprees will not even run without the airbox.
Not always true Tjamz I have had several honda sprees that would run like a raped ape with no air box. And yes I have had one up to 38(flat ground) with no air box and GPS verified. Most will run with out the air box you just have to turn in the air/fuel ratio screw in all the way. I do not suggest doing this but when you buy a spree for $20 and can ride it like that for a summer it is well worth the risk.[/quote]
This is pure BS. The fuel/air screw only effects idle to at most 1/4 throttle. It's effect at WOT is at best 1 to 2% of the fuel being used. What is this a Liar's Moon? Fantasies will not work here.
SpreeMadness520
Re: 40 MPH Spree
I will find a GPS, Take the aircleaner off and haul balls down the road if it will satisfy all of the downers lol
130cc Stroker
1984 Porsche 944
1965 Vespa
