spark plug
Mike
spark plug
Post by Mike »
in the manual it says "for extended high speed riding use a BPR8HS SPARK PLUG" how much faster would this be than the standard plug?
'86 Black/red two-tone Honda Spree, pretty much stock.
No_Stopping_A_Spree
Post by No_Stopping_A_Spree »
I don't think it would make it faster(if your talking about speed), it is just a cooler plug so the engine doesn't heat up too much(something like that) from extended use and being ran harder, in other words it helps it from over heating.
correct me if I'm wrong
Mike
Post by Mike »
o alright thanks
Musicman823
Post by Musicman823 »
yes
MySpree
Post by MySpree »
yup
niftyfifty
Post by niftyfifty »
In the workshop manual i should be using the standard BPR6HSA as it is after 1985. But could i get away with using a BPR6HS the pre 1985 plug?
MySpree
Post by MySpree »
i have a split fire in my aero...
darat
Post by darat »
uh i got on but it is not in anything... as of now
MySpree
Post by MySpree »
what?
darat
Post by darat »
I have one but it is not in anything ..
MySpree
Post by MySpree »
o..... i like mine... it works well
Mike
Post by Mike »
whats the difference between split fire and NGK or w/e its called
MySpree
Post by MySpree »
well the split fire is well split so spark comes out the sides and though the split in it...
Mike
Post by Mike »
so i take it that it could make a stock spree go a little bit faster? or am i wrong.
MySpree
Post by MySpree »
idk maby 1 mph if that... but accel is better and throttle response is better too.
