Idle issues
bartle90
Idle issues
Post by bartle90 »
This morning I started up my 98 elite sa50p and is seemed to be idling very low. When i would stop at a stop light I would have to keep giving it gas or it would stall out. When I got home and put it on the stand however, it started to accelerate very quickly. So basically when the wheel is on the ground it idles very low but once I put it on the stand it starts to accelerate rapidly. What is causing this?
Thanks
fastplastic
Re: Idle issues
Post by fastplastic »
well sounds like you might have a vac. leak......
bartle90
Re: Idle issues
Post by bartle90 »
Ok so how would I go about fixing/diagnosing this?
Thanks
bakaracer
Re: Idle issues
Post by bakaracer »
It sounds like it could also be the clutch engaging all the time just a little. Check the trans. There might be a weight that might be stuck or the rear pulley is not closing all the way.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Re: Idle issues
fastplastic wrote:well sounds like you might have a vac. leak......
Vacuum leaks make them idle fast, not slow.
fastplastic
Re: Idle issues
bartle90 wrote:it starts to accelerate rapidly
Like this bear?
