This morning I started up my 98 elite sa50p and is seemed to be idling very low. When i would stop at a stop light I would have to keep giving it gas or it would stall out. When I got home and put it on the stand however, it started to accelerate very quickly. So basically when the wheel is on the ground it idles very low but once I put it on the stand it starts to accelerate rapidly. What is causing this?
Thanks
Idle issues
- fastplastic
Re: Idle issues
well sounds like you might have a vac. leak......
Re: Idle issues
Ok so how would I go about fixing/diagnosing this?
Thanks
Thanks
Re: Idle issues
It sounds like it could also be the clutch engaging all the time just a little. Check the trans. There might be a weight that might be stuck or the rear pulley is not closing all the way.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
Re: Idle issues
Vacuum leaks make them idle fast, not slow.fastplastic wrote:well sounds like you might have a vac. leak......
- fastplastic
Re: Idle issues
Like this bear?bartle90 wrote:it starts to accelerate rapidly
