Sprelite The Begining Of My Epic Build
SpreeMadness520
Post by SpreeMadness520 »
Here are my plans,
50mm Taiwan bore with CHT gauge
Keli or Polini Performance Clutch (1500k)
Some Type Of Racing Variator
And 9 To 1 Gears.
Looking For A Throttle Cable For The Dio And Probably Brake Cable. Hit Me Up Thanks
130cc Stroker
1984 Porsche 944
1965 Vespa
Re: Sprelite The Begining Of My Epic Build
The spree you rode had 9.1:1 gears
My elite had 8.4:1 gears
:imo: 9.1:1 gears on a 85cc spree/dio will be a wheelie machine :surprise:
fastplastic
Post by fastplastic »
mine with non worn out tranny parts is a wheelie machine..... look more towards 7.9 or 8.4s
SpreeMadness520
fastplastic wrote:mine with non worn out tranny parts is a wheelie machine..... look more towards 7.9 or 8.4s
I really liked the elites gearing so i will try to get 8.4s or any other good suggestion
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520
Is 99mm off the left side of the elite engine mount correct?
Elite engine mount
Elite engine mount
Last edited by SpreeMadness520 on Fri Apr 08, 2011 6:46 pm, edited 1 time in total.
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520
How much do I take off of the top part?
Elite Engine Mount
Elite Engine Mount
130cc Stroker
1984 Porsche 944
1965 Vespa
We measured the stock Elite E Mount. Then marked it on the Elite S mount.
You can do the same with the spree mount.
SpreeMadness520
Ok I See That Doesnt Seem To Hard How Much Do I Take Off Of The Top Part With The Rubber Bumper?
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520
Engine Off, Cutting The Elite Mount Monday
Missing an engine.jpg (71.01 KiB) Viewed 13183 times
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520
Still Need To Know How Much To Take Off Of The Stem W/Bumber
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520 wrote:Still Need To Know How Much To Take Off Of The Stem W/Bumber
Enuff so the rubber bumper is in the middle of the hole on the frame. :nerd:
SpreeMadness520
Ok can I use a spree shock? I think the bolt I need is M10 140mm.
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520
Wow that cut is going to be real close to the arm
more pics 002.jpg (142.06 KiB) Viewed 13158 times
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520
Cut the metal piece off of the spree mount
more pics.jpg (136.43 KiB) Viewed 13144 times
130cc Stroker
1984 Porsche 944
1965 Vespa
