EPIC 1985 aero 50/80 swap
PolarIce
Re: EPIC 1985 aero 50/80 swap
Post by PolarIce »
Sorry BC I got your pm let me see what I can get for measurements.
1984 Honda NN50 Gyro
1986? Honda Aero 50
Served Onboard 94-97
PolarIce
Post by PolarIce »
Here's the headpipe.
1986? Honda Aero 50
bc117
Post by bc117 »
hey thanks now can you get a pic of the other end
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
bc117
Post by bc117 »
so i got my motor yesterday :geekdance: now i only have a few problems i have to adress and i should be good to go
i am missing the slide and cap to the carb and one of the rings was stuck in the piston even after a day sitting in carb cleaner and an hour in the ultra sonic cleaner plus a bake in the oven at 450 degrees :crazy: , i ended up having to pry it out with a small pick breaking it into pieces so now i am on the look out for at least one standard bore ring for either an aero 80 or cr80
Bear do you know if the cr80 rings will fit in the aero piston and will +0.25 rings be made to fit, both the piston and bore are immaculate so i don't think i need a new piston or rebore
1985 aero 50
ported
custom exhaust
ruckus vario
PolarIce
Post by PolarIce »
bc117 wrote:so i got my motor yesterday :geekdance: now i only have a few problems i have to adress and i should be good to go
Glad it was received in one piece but sorry to hear about the rings. :oops: My only quick check when I bought it was to see if the kickstart would move the piston.
Glad to hear the internals look good and I look forward to watching your build. Thanks again. :2thumbs:
1986? Honda Aero 50
My race motor pistons only had one ring. Back in the day all 2 strokes pistons had 3 rings, no the standard is 2.
Post by eliteguy50 »
How far back is that?
bc117
Post by bc117 »
I think the whole 1- 3 ring difference is all piston company/engine maker's discretion, most 2 stroke mx motors ive seen come with 1 ring pistons, cause they only need to last a couple races
yeah my 1983 cr80 has a two ring piston, i guess i could steal the piston outa that bike but im trying to sell it sigh :roll:
heres some pics
1985 aero 50
ported
custom exhaust
ruckus vario
Back in the '70s and before every thing had 3 rings. In the 80's the change over to 2 rings was completed. But even back in the 70's single ring race pistons existed.
spree-rider
Post by spree-rider »
current day gopeds have only 1 ring so they can rev high.
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
spree-rider wrote:current day gopeds have only 1 ring so they can rev high.
Porting, induction system and exhaust system have more to do with revving high the the number of rings. More rings just increases drag which hurts house power production.
:naughty: so that is how I increase my house power. One ring is sometimes used just for cheaper production costs.
:oops: a good spell checker does not preclude a proper and thorough proof reading. :lol:
We all do it now and then. It was just funny to me because we lost electricity last evening.
bc117
Post by bc117 »
finally back heres my progress so far got the engine in with very little fuss, no frame modification what so ever... yet :nervous: just had to modifify the engine hanger to be wide enough by splicing both the 50's+80's together but now i have a serious ride hight issue :surprise:
1985 aero 50
ported
custom exhaust
ruckus vario
