The identity of the driver for this test had to be kept secret.
This is how i drain the fuel, i dunno how you guys do it, but i just hook the vacuum pump up to the one line and drain the rest.
This is my catchcan setup, decided to take the fairings off so i could just use the stock oil line, for the first test i zip-tied my elite S oil pump wide open. For the second test i cut the zip tie on the road so it was "stock" and shut.
This was a test to find out how much oil the stock oil pump pumps when it is shut, when it is tied wide open, or if you were to put a split cable on the stock elite 01 elite S, the third test which i will conclude when i get the elite SR pump in the mail is when that pump is held wide open.
The scooter is a stock bore, stock carb, stock muffler (see my other tech thread, is my elite S exhaust de-restricted), stock gearing. Running an OKO variator with 9 gram weights, stock belt, stock rear pulley and clutch, and a 78 jet. I put the 78 jet in because i was partially worried that running the premix of 32:1 through the jet might lean out the mixture.
test one results - STOCK TIED OPEN
after putting 32 ounces of premix into the dry tank and riding 98% WOT for 17.25 miles i ran out of gas. I then measured the amount of oil in the catch can. Now there was some oil left in the catchcan and the glass but not much. Normally you might want to round down to the side of caution but it was about 12 cc of oil or .405 ounces per 1/4 gallon of premix used, or 1.62 ounces per gallon, or about 76.5:1 oil gas mixture.
test two results STOCK WITH OIL PUMP CLOSED
oddly enough the 32 ounces only got me 14 miles on this test and i rode the same exact course as the first test. As you can see i didn't take the picture straight on with the syringe because the flash kept screwing the pic up, it was about 7 cc of fluid or .236 ounce or .9464 ounces per gallon or 135:1 oil gas mixture
Either way you look at it, if wheelman's thoughts that 32:1 is a good ratio for a moded scoot, then you need to add about 2.38 ounces of oil to each gallon with the pump wired open to get 32:1. More results later next week for the SR pump.
