87 Elite se50P derestrict bang for the buck?
RIOT_S
Post by RIOT_S »
Good Day y'all!
So I finished fixing the need to fix in order to ride my Elite 50 on the street legally (blinkers, licensing, speedo / mileage) and now I am on to bigger and better things :coolcruise:
Wondering what would net me the most additional top end speed:
1. adding non-restricted exhaust from and se50 or sa50
2. adding non-restricted ramp plate
3. adding non-restricted ramp plate AND keli variator
Thoughts?
Im hoping its non-restricted ramp plate and variator as of right now I cannot locate any exhaust options other than new performance and at this point, that much $$ is not in the works.
Thanks for the opinions and thoughts, helps one make a better choice!
RIOT
bakaracer
Re: 87 Elite se50P derestrict bang for the buck?
Post by bakaracer »
You can also use the exhaust from a 85-87 aero 50, 88-93 elite lx/sr. Get any of the aftermarket variators.any of them is better than the stock one. Also check to see if your se50p came with the 10to1 gears. Some of them came with it. Easy way to check is take the trans cover off and count how many times the clutch bell spins to 1 rear wheel revolution. You will either have the 11to1 or 10to1. You want the 10to1 gears. That will push your unrestricted setup to at least 50to55mph
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
RIOT_S
Post by RIOT_S »
Would this one work ( says it's from a spree ....)
http://item.mobileweb.ebay.com/viewitem ... 2532551397
Also, this doesn't look right tone from an se50
http://item.mobileweb.ebay.com/viewitem ... 4710379407
RIOT
Those are both spree exhausts.
No they will not fit.
You should avoid these de-restricting measures until you verify the Main jet in the carb. De-restricted Aero models with essentially the same block used a #82, which you'll also need if the ramp plate, airbox intake and especially the exhaust is opened up. Not sure what the SE50P stock jet was, but I'll bet it was smaller than 82.
RIOT_S
Post by RIOT_S »
Verification of the jet is basically checking it's not the "Iowa" model, right?
Post by eliteguy50 »
RIOT_S wrote:Verification of the jet is basically checking it's not the "Iowa" model, right?
To make sure you don't burn up your engine from lean conditions.
RIOT_S
Post by RIOT_S »
Help me understand: How does a non-restricted exhaust and non-restricted plate make the engine run " lean"?
vvvvvv. Wheelman is more eloquent .vvvvvv
RIOT_S Axt-ed:
Elementary, my dear RIOT-Son:
The stock jet is adequate to supply the RPM and heat loads that the engine will develop with the restricted pipe and variator limiters. Maybe it gins up 6500RPM, tops so restrained. Maybe even less.
Once uncorked with Pipe, your S engine's RPM and BMEP both go up, a LOT. Spinning up to 8500 or more, the engine will demand more fuel in the mixture than the stock jet can provide. Insufficient evaporative cooling from the drier fuel charge cause combustion chamber temperatures to rise into Dangerous range.
Fortunately, Honda-san has determined the optimal jet size for us; It's in the unrestricted version. Honda-san tended to jet a bit lean thanks to EPA Emissions rules, though. A size bigger than stock usually won't hurt anything.
RIOT_S
Post by RIOT_S »
Ok, thank you folks!
My question is now then: where in the he'll do I get a bigger jet and how hard is that to do? (here I was thinking this was too be easy... Never is is it!?). :)
RIOT_S
Post by RIOT_S »
RIOT_S wrote:Ok, thank you folks!
Alright, so I found the jet a bikebandit. That's good, but how hard is it to do? I am mechanically inclined BUT I have never worked on a carb...
Thanks!
If you've attended the Screwdriver Safe Operator's Class, not very hard.
You need to drain and dismount the carb. Two tight Phillips screws drop the bowl. Use a new bit, not your Granny's kitchen-drawer item.
A narrow slotted driver untwists the Main. Check the size engraved on it in case someone already swapped it.
Call your Honda dealer and read the Partsdude this nunber: 99101-187-0**0. Insert 78, 82, 85 and 88 in place of the stars for the size you want. Get all 4 for around $16.
Righty-tighty the selected size, reassemble the carb and reinstall. Go easy on the 2 8mm hex bolts at the carb flange. Al-you-minnie-yum is easy to strip if you eat too much Wheaties.
The FSM has step-by-step instructions you can follow, or search Wiki-Spreedia.
martynkim
Post by martynkim »
This is the pipe you need http://cgi.ebay.com/ebaymotors/1986-HON ... ccessories
or a leo vince SP3 :ndance: difficult to find. Worth the trouble to get though. :nervous:
RIOT_S
Post by RIOT_S »
martynkim wrote:This is the pipe you need http://cgi.ebay.com/ebaymotors/1986-HON ... ccessories
Ok, jetting aside, what accomplishes more: nonrestricted pipe OR variator and nonrestricted ramp plate?
Additionally, can I put in larger jet with the rest of it stock or do I need to do it coordinated?
