Spree upgrade path - input needed
Working on the Wiki again. I wanted to get a consensus from you all regarding the upgrade path for the Spree for the Wiki.
http://hondaspree.net/wiki/index.php5?t ... grade_Path
I think it's something like this:
1) Pulley mod
2) Enlarge stock manifold
3) Mill head / increase compression
3.1) Enlarge exhaust port
3.2) Construct expansion chamber
4) Upgrade to SB50 manifold and reeds
5) Bore kit
6) Gear ratio change
7) New carb (size?)
Pod filter's probably in here somewhere... though I've never gotten one to work... not sure what else. Maybe the order could differ. I've personally done 1-4 of the above, the rest not so much.
1) Pulley mod
5) Bore kit
7) New carb (size?)
Re: Spree upgrade path - input needed
If an owner has a beat 84/85 or dead powertrain - replacing with the 86/87 instead of another 84/85 engine has minor pluses.
- About 8.4% gear ratio change (11.49:1 vs 12.45:1)
- Minor porting difference.
- There is a domed piston on the 86/87, paired with the early head that gives higher compression w/o machining
- Kick start
I'd forgotten about the piston change from 84/85 to later. Good catch.
Also, the whole '86/87 motor is better in general. Didn't know about the ferrule change... jeez, why not keep that common? I'm yet to see one fail.
Don't the lever arms interchange so you could use the original lever and cable for rear brakes?
I would move step four up to step two. Then it could be an either or step. I think the intake should be addressed before machining the head. I would also add the sb50 exhaust to the list. It has better flow than the spree exhaust and does not require the skill to build a custom pipe.
- Trafficjamz
The sb50 exhaust will not fit a spree without an sb50 shock to go with it.eliteguy50 wrote:Don't the lever arms interchange so you could use the original lever and cable for rear brakes?
Why? There is the loss of the mounting point at the tail of the pipe but I don't see how the shock affects that. I didn't have any problems with it on my last spree.Trafficjamz wrote:The sb50 exhaust will not fit a spree without an sb50 shock to go with it.eliteguy50 wrote:Don't the lever arms interchange so you could use the original lever and cable for rear brakes?
- Trafficjamz
The e pipe will run into the spree frame if the e shock is not used.eliteguy50 wrote:Why? There is the loss of the mounting point at the tail of the pipe but I don't see how the shock affects that. I didn't have any problems with it on my last spree.Trafficjamz wrote:The sb50 exhaust will not fit a spree without an sb50 shock to go with it.eliteguy50 wrote:Don't the lever arms interchange so you could use the original lever and cable for rear brakes?
Oh, I must have swapped shocks without realizing it then.Trafficjamz wrote:The e pipe will run into the spree frame if the e shock is not used.
OK, so this then
First, consider swapping in a 1986 or 1987 Spree engine. These are known to be faster engines overall than the earlier engines.
1) Pulley mod (may require follow-up modifications depending on other changes)
2) Enlarge stock manifold (or do #6 instead)
2.5) Install domed piston from later engine (replacement for '84/'85 dished piston)
2.7) Swap earlier '84/'85 head to later engine.
3) Mill head to increase compression, targeting .020" running clearnace
4) Enlarge exhaust port
4.5) Install SB50 exhaust pipe and shock (shock change required for exhaust to fit.)
5) Construct expansion chamber
6) Upgrade to SB50 manifold and reeds
7) Bore kit
Gear ratio change
9) New carb (size?)
7) Bore kit
9) New carb (size?)
Step 9.5 could be an aftermarket intake like the CT with a custom adaptor. That would complement the custom exhaust pipe. Then run a 19mm with the 48mm BBK.
Step 10 could be swap in a variated af05 or Dio.
+1 on step 10.
- Trafficjamz
Step 4.5
Get some Malossi fiberglass reeds.
- malossireeds.JPG (25.88 KiB) Viewed 7285 times
these fit sb50 reed block? do you have a part number?
1986 Spree SE:
- pulley mod
'85 head
SB50 intake, reeds, carb
UNI filter
44mm bbk
3x10 conti zipps
next:
taz gears, sa50 clutch w/ 2k springs
How about bigger tires? 2.75x10's are nice, and they JUST fit after grinding out about 1/2" of the center-stand on one side. They even fit (with about 1/16" to spare) inside the plastic mudguard in the aft-end. The center-stand can tolerate the hacking, but you can also weld the newly-opened gap shut if you're nervous about it.noiseguy wrote:Working on the Wiki again. I wanted to get a consensus from you all regarding the upgrade path for the Spree for the Wiki.
- fastplastic
you FAILJJ Joseph wrote:2.75x10's are nice, and they JUST fit after grinding out about 1/2" of the center-stand on one side. They even fit (with about 1/16" to spare) inside the plastic mudguard in the aft-end. The center-stand can tolerate the hacking, but you can also weld the newly-opened gap shut if you're nervous about it.
