Flash 3.26
Re: Flash 3.2: 72cc Corsa!
Greetings;
I knew it had a bit more, not this much.
Wind 5-10 on left rear quarter. Call it a broad reach.
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
:shock: :shock:
Dang man thats insane!!
Ya get any speed wobbles at the kind of speed?
Biggest question of all: Are ya still holding it back?
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
Wheelman-111 wrote:Greetings;
Rag sailor terminology, in dirt water Texas no less. :thumbwink:
evilone
Post by evilone »
You got me by .1 mph :thumbwink:.
Petrock's 1984 Spree...at them speeds my elite was super smooth like a cadillac!
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
No wobbles at all. Elite 95mm drums not nearly enough is the only Fear factor.
Only hold-backs are imposing Wheelman Frontal Area and only 1/2 mile run. Mirrors on, Courier satchel on my back and Wheelman don't tuck.
Get better than Spree brakes to stay alive.
Bear I used to be a pretty fair windsurfer.. Corpus bay is windy enough to get fast anywhere else.
I've been measured at 36 Kts. Like the Elite, I know I've gone faster.
I think i'd be too sketched out to even try to go that fast :nervous:
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
I'll go that fast on my Aero 125 without worry (CT and at least a 24 OKO and an exhaust), even on the Aero 80 if I ever do any real hot rodding to it BBK and CT with a 21 to 24 OKO and an exhaust, actually I already have every thing except the piston and rings). But on my 50 cc scooters, not gonna happen.
Re: Flash 3.26
Sorry this belonged here...
Main is now 125 methinks. Temp didn't top 350.
Geartrain harshness still happening, but nothing grenaded.
catsailor
Re: Flash 3.26
Post by catsailor »
wheels,
lol at the broad reach. Are you also a "ragman"? Springtime here in New England too. Looking forward to a long broad reach on my badass catamaran within the month.
1984 Spree With Taz BBK and Gears
1988 Seawind 24 Catamaran
Re: Flash 3.26
Cat, I used to be a fair-to-decent windsurfing racer. As often happens, life moves you on to other things, but sailing's in my blood.
Re: Flash 3.26
I learned rag sailing in my youth with an El Toro sailing dingy. I have also sail cats, 18 and 25 foot monos. Years later I trade the El Toro as a down payment on my first race boat. The wife wanted a sail boat, so I bought her a Seattle made Nelson Plastics 8 foot fiberglass sailing dingy. It got stolen, just the boat, I still had the rigging, and just last year I found another Nelsons Plastic sail boat sans the rigging. I got it for free and when I checked the numbers it was my boat to start with. Strange!
catsailor
Re: Flash 3.26
Post by catsailor »
I started as a kid on a sunfish, raced J24's in college, and larger monos after college both blue water and beercan racing. Switched to a catmaran about 10 years ago, and wont go back to a mono. Nothing like sailing at 20kts flat vs 8kts on an incline.
Well as temps here in Deepinnaharta warm to Mid-Spring levels - Lows in low 70s, highs in low 80s - my 52/125 combination may be getting too rich. Used CustomX22 Corsa bore now has 35 hours and about a thousand miles. I'm none-too-anxious to drop my 52 pilot because of the reassuringly low temps at barely-cracked throttle and the absence of heat spikes. WOT seems to stabilize at about 360 - fuzzy VDO gauge and fuzzier Wheel-vision notwithstanding- with the 126 Main in the OKO 26. It's the messy area in between that's been getting worse. Raspy, stumbly, particularly since my +1000 spring may be getting softer (along with other Wheel-Parts...) and drops the RPM rather rudely at about 40 MPH, right where the part-throttle goes a bit rich - again according to the gauge.
So I examined my K44 needle and marked it at 50% and 25% from the tip - see page 2-3 of this thread. I found the JHK or somesuch had just about .10mm thicker at the middle and about the same at the tip. In it went, producing a much cleaner 1/4-3/4 throttle linearity and no change in peak or off-throttle temps. More testing to be done, documenting mostly for myself here.
Re: Flash 3.26
Sorry, forgot this other thread...
Well as temps here in Deepinnaharta warm to Mid-Spring levels - Lows in low 70s, highs in low 80s - my 52/125 combination may be getting too rich. Used CustomX22 Corsa bore now has 35 hours and about a thousand miles. I'm none-too-anxious to drop my 52 pilot because of the reassuringly low temps at barely-cracked throttle and the absence of heat spikes. WOT seems to stabilize at about 360 - fuzzy VDO gauge and fuzzier Wheel-vision notwithstanding- with the 125 Main in the OKO 26.
It's the messy area in between that's been getting worse. Raspy, stumbly, particularly since my +1000 spring may be getting softer (along with other Wheel-Parts...) and drops the RPM rather rudely at about 40 MPH, right where the part-throttle goes a bit rich - again according to the gauge. It was getting just about impossible to ride between 35 and 40 MPH, fine slower and faster, but wouldn't maintain 38.
Well, the thicker needle was a step in the right direction, but Flash 3.26 still had a hard time keeping its throat clear in the midrange. Temps decidedly low - 250 in the midrange cruising mode. I decided to tempt Fate and swapped the 52 for a 50 Pilot. Much better, without discernible impact on middy temps and no heat spikes. I'll check and probably replace the crusty BR8-HIX plug and do a few reads. Sprinted to 66 in under a quarter-mile, and temps stayed at or under 350 at WOT too.
