spree starving for fuel
fra
Post by fra »
Have 85 spree that has not run for 3-4 years. Replaced the gas and it fires but will not run. Starving for fuel. Checked vaccum line and there is vaccum, but fuel is not flowing from fuel valve. What should I do. Also have 85 Aero 50 and it runs like a top. Thanks
fra
odinxxix
Re: spree starving for fuel
Post by odinxxix »
check to make sure that the tank is not clogged, remove petcock and see if fuel flows from the tank if it does then clean or replace petcock. are you sure it is enough vacuum? pull the 2 hoses off and suck on the bottom one and see if fuel flows from the top hose.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
fra
Post by fra »
Thanks I will pull the hoses and check.
fra
ciccanti38
Post by ciccanti38 »
help i have an 86 spree it also is starving for fuel pulled the vacuum line and sucked and gas came out but installed it back on the manifold and tried to start it and i get no fuel to the carb anyone know what could be the problem
bc117
Post by bc117 »
you need to take the carb apart and see if the float is allowing fuel to enter the bowl
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
The needle is probably stuck closed.
ciccanti38
there is no vacuum to open the petcock but when i remove the air boot and cover the intake with my hand i regain vacuum and the bike will start
Are you leaving the throttle closed when trying to start it?to
ciccanti38
got it to start and run sounds perfect but wont pull me up the road and im only 160 lbs any suggestions
killingspree1985
Post by killingspree1985 »
had this problem.....its the carb...... look at post spree wont go and click on the link bear posted and ur problem will be fixed..
